Automatically remove duplicate fields
Hello @LyricsLover, here are the first 2 questions I wrote at the beginning:
I'll explain in more detail:
When I choose my audio file, by opening Mp3tag, I would like the program to be able to remove the duplicate data BPM 120\\120, without saving the file, before displaying my data from my audio file on the screen, to have the following result BPM 120, which would allow me to always keep my 2 tags BPM 120, when I save with a Tools (If this data is not deleted, if I don't look before saving, I will add another data \\120)
As you know, Mp3tag and the Actions: Remove duplicate Fields command: Saves in the audio file, the tags, BPM (TBPM) which is normal, on the other hand it deletes my 2nd Tag BPM (BPM)
I would have liked to have this command option, which I have written at the beginning of this text, I understand very well that Mp3tag, is not configured this way, and that there is no command in Mp3tag Options
I will accommodate it, there is no problem,
Thanks to @ohrenkino and you LyricsLover, I just programmed Actions: To export my images to a folder, it works very well, it's fast, I will save time in programming, it's great...
