Thanks for the reply.
The formatting of the tags is all wrong, being uppercase so can't take any information from that and want to ensure all words are correctly capitalised.
I could have sworn this worked before, but can't see to get it to work now.
I tried introducing Replace with regular expression to _DIRECTORY as a test using '^' and then replace with '{'. Then the appropriate code. At the end I added Replace with regular expression to _DIRECTORY and inserted '{' replace with ''. It did not make a difference.
I really like this code, but it is not fixing capitalisation correctly and I don't know why.
Yet this does (but not quite how I want it to as doesn't have same extensive ruleset):
So what is the difference between the two actions and why does the second one impact upon case of the directory when the other doesn't?
The other interesting quirk is that the first action (when it works) manages to add a capital to the beginning of anything after opening brackets(except for .feat) but the second doesn't. Why is that?
Combining them works for the most part (any titles which contain 'a' after the track number stay in lower case though).
[#0]
T=1
F=_TAG
1=1
2=
[#1]
T=4
F=_TAG
1=\\\\b(A|An|The|And|But|Or|So|After|Before|Out|When|While|Since|Until|Although|Even If|Because|About|Above|Across|Against|Along|Alongside|As|At|Below|By|During|For|From|In|Into|Of|Off|On|Onto|Over|Than|Through|Till|To|Under|Up|With|Within|Without)\\\\b
2=$lower($1)
3=0
[#2]
T=4
F=_TAG
1=^\\\\s*(\\\\w+)
2=$caps($1)
3=0
[#3]
T=4
F=_TAG
1=(\\\\w+)\\\\s*$
2=$caps($1)
3=0
[#4]
T=1
F=_FILENAME
1=1
2=
[#5]
T=4
F=_FILENAME
2=$lower($1)
3=0
[#6]
T=4
F=_FILENAME
1=^\\\\s*(\\\\w+)
2=$caps($1)
3=0
[#7]
T=4
F=_FILENAME
1=(\\\\w+)\\\\s*$
2=$caps($1)
3=0
[#8]
T=1
F=_DIRECTORY
1=1
2=
[#9]
T=4
F=_DIRECTORY
2=$lower($1)
3=0
[#10]
T=4
F=_DIRECTORY
1=^\\\\s*(\\\\w+)
2=$caps($1)
3=0
[#11]
T=4
F=_DIRECTORY
1=(\\\\w+)\\\\s*$
2=$caps($1)
3=0
[#0]
T=4
! Trim Trailing, Preceding & Extra Spaces [1]=
F=_DIRECTORY
1=(\\s+$|^\\s+)
2=
3=0
[#1]
T=4
! Trim Trailing, Preceding & Extra Spaces [2]=
F=_DIRECTORY
1=\\s+
2=
3=0
[#2]
T=4
! Enforce Correct Word Spacing [1]=
F=_DIRECTORY
1=([^\\s\\.;\\)\\]/])([&\\({\\[\\+])
2=$1 $2
3=0
[#3]
T=4
! Enforce Correct Word Spacing [2]=
F=_DIRECTORY
1=(&|\\)|\\}|\\]|;|(?<!\\d),|,(?!\\d{3})|\\+)([^\\s\\.;\\(\\[/])
2=$1 $2
3=0
[#4]
T=4
! Enforce Correct Word Spacing [3]=
F=_DIRECTORY
1=\\b([a-z])\\s(&)\\s([a-z])\\b
2=$1$2$3
3=0
[#5]
T=4
! Enforce Correct Word Spacing [4]=
F=_DIRECTORY
1=([\\(\\[])\\s
2=$1
3=0
[#6]
T=4
! Enforce Correct Word Spacing [5]=
F=_DIRECTORY
1=\\s(\\]|\\)|\\?|:|;|,|\\.(?!\\.\\.))
2=$1
3=0
[#7]
T=4
! Enforce Correct Word Spacing [6]=
F=_DIRECTORY
1=(".*?")([^\\s\\]\\)/\\}!\\-\u003d,.;])(?!$)
2=$1 $2
3=0
[#8]
T=4
! Enforce Correct Word Spacing [7]=
F=_DIRECTORY
1=([^\\s\\[\\(/\\{])(".*?")
2=$1 $2
3=0
[#9]
T=4
! Enforce Correct Word Spacing [8]=
F=_DIRECTORY
1=(\\.(?<!\\.\\.))(?![\\s\\.':;\\)\\]"])(?)(?!$)(?!\\d)(?!(co|com|uk|net|org|gov|edu|mil|html?|php))
2=$0
3=0
[#10]
T=4
! Enforce Correct Word Spacing [9]=
F=_DIRECTORY
1=ww.\\s
2=ww.
3=0
[#11]
T=4
! Enforce Correct Word Spacing [10]=
F=_DIRECTORY
1="\\s?(.*?)\\s?"
2="$1"
3=0
[#12]
T=4
! Add Apostrophe to "Are" Contractions=
F=_DIRECTORY
1=\\b(how|they|what|when|why|you)re\\b
2=$1're
3=0
[#13]
T=4
! Add Apostrophe to "Have" Contractions=
F=_DIRECTORY
1=\\b(could|how|i|might|must|should|we|what|where|would|you)ve\\b
2=$1've
3=0
[#14]
T=4
! Add Apostrophe to "Is" Contractions=
F=_DIRECTORY
1=\\b(he|here|how|she|that|there|two|what|when|where|who|why)s\\b
2=$1's
3=0
[#15]
T=4
! Add Apostrophe to "Not" Contractions=
F=_DIRECTORY
1=\\b(ain|aren|can|couldn|didn|doesn|don|hadn|hasn|haven|isn|mightn|mustn|shouldn|wasn|weren|won|wouldn)t\\b
2=$1't
3=0
[#16]
T=4
! Add Apostrophe to "Will" Contractions=
F=_DIRECTORY
1=\\b(how|it|that|there|they|what|when|where|who|you)ll\\b
2=$1'll
3=0
[#17]
T=4
! Title Case Conversion [1] (Convert Words to Mixed-Case, Ignoring Upper-Case Letters)=
F=_DIRECTORY
1=([-({\\[\\]}) _",.+&@;*])(\\l)
2=$1$upper($2)
3=1
[#18]
T=4
! Title Case Conversion [2] (Capitalise First Word)=
F=_DIRECTORY
1=^(\\l)
2=$upper($1)
3=1
[#19]
T=4
! Title Case Conversion [3] (Articles, Conjunctions & Short Prepositions to Lower-Case, Except Before or After Punctuation)=
F=_DIRECTORY
1=(?<!&|:|;|-|/|!|(?<![A-Z]\\.[A-Z])\\.|\\?|\\+)(\\s+\\b(A|An|And|As|At|But|By|De|Et|For|From|In|Into|Le|Nor|Of|Off|On|Onto|Or|So|Than|The|To|Upon|Von|With)(?\u003d\\s)(?!\\s[\\-\\(\\)\\[\\]{}]))
2=$lower($1)
3=1
[#20]
T=4
! Title Case Conversion [4]=
F=_DIRECTORY
1=(^|\\s|\\(|\\[|/)'(.{1})
2=$1'$upper($2)
3=0
[#21]
T=4
! Title Case Conversion [5] (Capitalise "to" Before Common Verbs)=
F=_DIRECTORY
1=(to\\s+)\\b(Ask|Be|Begin|Believe|Bring|Buy|Call|Care|Change|Cheat|Come|Cry|Dance|Die|Do|Dream|Fall|Feel|Find|Forget|Get|Give|Go|Hate|Have|Hear|Hide|Hold|Keep|Know|Laugh|Learn|Leave|Let|Lie|Listen|Live|Look|Lose|Love|Make|Mean|Miss|Move|Marry|Need|Play|Pretend|Promise|Put|Remember|Return|Ride|Run|Say|See|Sell|Send|Set|Show|Sing|Speak|Stand|Stay|Steal|Stop|Take|Talk|Tell|Thank|Think|Touch|Travel|Try|Use|Wait|Walk|Want|Win|Wish|Work|Write)\\b
2=$caps($1)$2
3=1
[#22]
T=4
! Forced Upper-Case for Named Abbreviations and Acronyms=
F=_DIRECTORY
1=\\b(ac|aka|ap|asap|atm|bbc|bc|bce|blt|btw|cbs|cc|cd|cia|dc|dj|doa|emi|ep|faq|fbi|fm|fr|gb|gi|imho|ira|irs|jc|kkk|lp|mc|mgm|nasa|nbc|npr|ny|nyc|ok|ost|pm|ps|qed|rca|rpm|sos|tba|tlc|tv|ufo|uk|usa|ussr|va|ymca)\\b
2=$upper($1)
3=0
[#23]
T=4
! CamelCase Irish Names Beginning with O'=
F=_DIRECTORY
1=\\b(O'[a-z]|O\\x{2019}[a-z])
2=$upper($1)
3=1
[#24]
T=4
! CamelCase Scottish Names Beginning with Mc=
F=_DIRECTORY
1=\\b(Mc)((?:[a-z]|-){3,})
2=$1$caps2($2,-)
3=1
[#25]
T=4
! CamelCase Common Scottish Names Beginning with Mac=
F=_DIRECTORY
1=\\b(Mac)(Alister|Arthur|Askill|Bain|Coll|Donald|Dougall|Dowell|Duff|Ewen|Farlane|Gregor|Intyre|Kenzie|Kinnon|Laren|Lean|Leod|Millan|Nab|Neil|Pherson|Rae)\\b
2=$1$caps2($2)
3=0
[#26]
T=4
! Roman Numerals to Upper-Case (Up to LXXIX, or 89)=
F=_DIRECTORY
1=\\b(?:L?X{0,3}|XL)(?:V?I{0,3}|I[VX])(?\u003d(\\.\\s|\\s|\\)|$))
2=$upper($0)
3=0
[#27]
T=4
! Common Latinisms and Miscellany to Lowercase=
F=_DIRECTORY
1=(\\b(?:E\\.G|et\\sAl|Etc|I\\.E|Versus|Vs|Feat\\.\\s|Ft\\.\\s|(?<\u003d')N(?\u003d'))\\b)
2=$lower($1)
3=1
[#0]
T=4
F=_TAG
1=(\\s+$|^\\s+)
2=
3=0
[#1]
T=4
F=_TAG
1=\\s+
2=
3=0
[#2]
T=4
F=_TAG
1=([^\\s\\.:;\\)\\]/])([&\\({\\[\\+])
2=$1 $2
3=0
[#3]
T=4
F=_TAG
1=(&|\\)|\\}|\\]|;|(?<!\\d),|,(?!\\d{3})|\\+)([^\\s\\.:;\\(\\[/])
2=$1 $2
3=0
[#4]
T=4
F=_TAG
2=$1$2$3
3=0
[#5]
T=4
F=_TAG
1=([\\(\\[])\\s
2=$1
3=0
[#6]
T=4
F=_TAG
2=$1
3=0
[#7]
T=4
F=_TAG
1=(".*?")([^\\s\\]\\)/\\}!\\-\u003d,.;:])(?!$)
2=$1 $2
3=0
[#8]
T=4
F=_TAG
2=$1 $2
3=0
[#9]
T=4
F=_TAG
2=$0
3=0
[#10]
T=4
F=_TAG
1=ww.\\s
2=ww.
3=0
[#11]
T=4
F=_TAG
1="\\s?(.*?)\\s?"
2="$1"
3=0
[#12]
T=4
F=_TAG
2=$1're
3=0
[#13]
T=4
F=_TAG
2=$1've
3=0
[#14]
T=4
F=_TAG
2=$1's
3=0
[#15]
T=4
F=_TAG
2=$1't
3=0
[#16]
T=4
F=_TAG
2=$1'll
3=0
[#17]
T=4
F=_TAG
1=([-({\\[\\]}) _",./+&@:;*])(\\l)
2=$1$upper($2)
3=1
[#18]
T=4
F=_TAG
1=^(\\l)
2=$upper($1)
3=1
[#19]
T=4
F=_TAG
2=$lower($1)
3=1
[#20]
T=4
F=_TAG
2=$1'$upper($2)
3=0
[#21]
T=4
F=_TAG
2=$caps($1)$2
3=1
[#22]
T=4
F=_TAG
2=$upper($1)
3=0
[#23]
T=4
! Replay Gain Correction [1]=
F=REPLAYGAIN_TRACK_GAIN
1=(\\+|-)?\\s?(\\d*\\.\\d*)\\sDB
2=$1$2 dB
3=0
[#24]
T=4
! Replay Gain Correction [2]=
F=REPLAYGAIN_ALBUM_GAIN
2=$1$2 dB
3=0
[#25]
T=4
F=_TAG
2=$upper($1)
3=1
[#26]
T=4
F=_TAG
2=$1$caps2($2,-)
3=1
[#27]
T=4
F=_TAG
2=$1$caps2($2)
3=0
[#28]
T=4
F=_TAG
2=$upper($0)
3=0
[#29]
T=4
F=_TAG
2=$lower($1)
3=1
[#30]
T=4
F=_FILENAME
1=(\\s+$|^\\s+)
2=
3=0
[#31]
T=4
F=_FILENAME
1=\\s+
2=
3=0
[#32]
T=4
F=_FILENAME
2=$1 $2
3=0
[#33]
T=4
F=_FILENAME
2=$1 $2
3=0
[#34]
T=4
F=_FILENAME
2=$1$2$3
3=0
[#35]
T=4
F=_FILENAME
1=([\\(\\[])\\s
2=$1
3=0
[#36]
T=4
F=_FILENAME
2=$1
3=0
[#37]
T=4
F=_FILENAME
2=$1 $2
3=0
[#38]
T=4
F=_FILENAME
2=$1 $2
3=0
[#39]
T=5
F=_FILENAME
1=$regexp(%_filename%,'(\\.(?<!\\.\\.))(?![\\s\\.'''';\\)\\]"])(?)(?!$)(?!\\d)(?!(co|com|uk|net|org|gov|edu|mil|html?|php))',$0 )
[#40]
T=4
F=_FILENAME
1=ww.\\s
2=ww.
3=0
[#41]
T=4
F=_FILENAME
1="\\s?(.*?)\\s?"
2="$1"
3=0
[#42]
T=4
F=_FILENAME
2=$1're
3=0
[#43]
T=4
F=_FILENAME
2=$1've
3=0
[#44]
T=4
F=_FILENAME
2=$1's
3=0
[#45]
T=4
F=_FILENAME
2=$1't
3=0
[#46]
T=4
F=_FILENAME
2=$1'll
3=0
[#47]
T=5
F=_FILENAME
1=$regexp(%_filename%,'([-({\\[\\]}) _",.+&@;*])(\\l)',$1\\u$2)
[#48]
T=4
F=_FILENAME
1=^(\\l)
2=$upper($1)
3=1
[#49]
T=4
F=_FILENAME
2=$lower($1)
3=1
[#50]
T=4
F=_FILENAME
2=$1'$upper($2)
3=0
[#51]
T=4
F=_FILENAME
2=$caps($1)$2
3=1
[#52]
T=4
F=_FILENAME
2=$upper($1)
3=0
[#53]
T=4
F=_FILENAME
2=$upper($1)
3=1
[#54]
T=4
F=_FILENAME
2=$1$caps2($2,-)
3=1
[#55]
T=4
F=_FILENAME
2=$1$caps2($2)
3=0
[#56]
T=4
F=_FILENAME
2=$upper($0)
3=0
[#57]
T=4
F=_FILENAME
2=$lower($1)
3=1
