Changing part of filename
Yes, it is not changing the file name.
it's 455 files, but in groups of 34, so fare.
I know, of course not.
That is why I asked you to check whether the DISCNUMBER field contains the correct number for each group that should have the same number.
This is how it looks.
I think you still have to define the "Next disc on change of" where I would suggest TITLE.
Do not tick "Save count of discs".
To check if the result is OK, see the extended tags dialogue Alt-T - and be so kind to share a screenshot of that dialogue for a single file.
Thanks for the feedback, but I thought there was an easy way to do it, that someone had already tried on the filename itself :slight_smile:
The problem is not the manipulation of the filename - but the special grouping that you have in mind.
No program can guess where you want to increase the number unless you give a criterion that tells the program when to change something.
It is a pity really, that you did not supply the requested information.
So this means in the end that you either have to do it manually, half automatic with the $replace() function or with a different program for file handling.
Yes, I think you are right, but there is no increase in number, every croup of name will have same number.
Here is another attempt:
If the current numbers are correct, only that they have to be increased by 1, then try
Convert>Tag-Tag for _FILENAME
Format string: $num($add($num(%_filename%,3),1),3) - $regexp(%_filename%,^\d+ - ,)
No different outcome, I do not think that program work on file names.
That is most astounding as it looks like this in my machine:
and that clearly shows that the 000 is changed to 001
It worked, I just had to type the name at the top as I couldn't choose from the list, thank you very much :slight_smile:
Can you explain to me how the 3 numbers work? I entered 1 and 2 and it worked fine, but from 3 on it was wrong.
Where did you enter numbers?
My format string was intended to add a 1 to any leading number and write that back. So 5 > 6, 4 > 5, 3 > 4, 2 > 3, 1 > 2, 0 > 1.
In the middle, I tried a little again, and I got it to work.
Sometimes it comes up with 2 numbers, both the one I change from and the one I change to.
The hyphen in the original filename is no "minus" character but something else (looks longer).
So the original number does not get deleted as that checks for a pattern "number followed by space and minus".
