# Columns for Tag Sources with Cover Preview are offset by one on first use
**URL:** https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678
**Category:** Fixed Bugs
**Tags:** bug-fixed
**Created:** [May 14, 2024, 11:42am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678 "2024-05-14T11:42:05Z")
**Posts on this page:** 16
**Page:** 1
<div class="post-metadata">
### Author: ![yhsss](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/y/eb8c5e/32.png) [@yhsss](https://community.mp3tag.de/u/yhsss)
#### Post date: [May 14, 2024, 11:42am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/1 "2024-05-14T11:42:05Z")
</div>
Hi, new user here. Thank you for sharing this it is super useful. However I have found a bug, where the columns are not lined up with the correct names. I'm using v3.25d and 1.30 of your script
 ![image](https://community.mp3tag.de/uploads/default/original/3X/6/1/61ba003f24f4e685f9eec21d847ab11a0b9fa436.png)
### Author: ![LyricsLover](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/l/c6cbf5/32.png) [@LyricsLover](https://community.mp3tag.de/u/LyricsLover)
#### Post date: [May 14, 2024, 11:54am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/2 "2024-05-14T11:54:05Z")
</div>
Thank you @yhsss
What exactly do you mean with "are not lined up with the correct names"?
Could you please show me what line in your screenshot should contain what (other/additional?) content?
Ahhh wait: You mean the Column title like "No of Media" where "Taylor Swift" is the content`?
If I try it with `1989` as ALBUM and `Taylor Swift` as ARTIST I get:
 ![image](https://community.mp3tag.de/uploads/default/original/3X/f/2/f2d54c72e64c8cb2a98588e67c1525955bbc847c.png)
_What exactly did you use to get your "mixed up" column titles and content?_
If I try the search with `1989 (Taylor's Version)` as ALBUM and `Taylor Swift` as ARTIST
 ![image](https://community.mp3tag.de/uploads/default/original/3X/c/c/cc463626e32346332c35616f6fb4c35707448f5a.png)
I get this IMHO correct result:
 ![image](https://community.mp3tag.de/uploads/default/original/3X/e/c/ec707955c2a713528d6d0516d9382e90bc03a1ca.png)
#### Post date: [May 14, 2024, 12:05pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/3 "2024-05-14T12:05:28Z")
</div>
That is really odd. I downloaded v3.25d 64bit version because you mentioned I need minimum v3.25c. What version are you running? Somehow the order of the header seems all messed up.
#### Post date: [May 14, 2024, 12:06pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/4 "2024-05-14T12:06:21Z")
</div>
I use the Mp3tag 3.25d version currently.
#### Post date: [May 14, 2024, 12:08pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/5 "2024-05-14T12:08:09Z")
</div>
well looks like this has got me stumped. I'll try to uninstall the whole thing and try from scratch
#### Post date: [May 14, 2024, 12:10pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/6 "2024-05-14T12:10:26Z")
</div>
Please let me know if it helps.
And please doublecheck if you really have/use the newest 6 scripts (5 x `*.src` and 1 x `*.inc`) inside the configuration subfolder `\data\sources` of your Mp3tag installation.
#### Post date: [May 14, 2024, 12:16pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/7 "2024-05-14T12:16:38Z")
</div>
So I uninstalled it completely including removing all configuration. Reinstalled 3.25d 64bit. copied v1.30 of your script into the sources folder... now the columns are lined up but offset to the left. what gives?
 ![image](https://community.mp3tag.de/uploads/default/original/3X/f/1/f1c5c1c5df9c6795d583897bebc40a55e3ca806a.png)
#### Post date: [May 14, 2024, 12:19pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/8 "2024-05-14T12:19:58Z")
</div>
In my further tests I made in the meantime, I believe I have found a possible reason:
I'm using Mp3tag v3.25d and the screenshots above are from the 32bit-Version.
If I try the exactly same process and source files with the 64bit-Version, I can see the the same behaviour as you.
I need to check it with @Florian and let you know as soon as I see how I can fix that.
(BTW: The tagging itself is not mixed up, right? It's "only" the offset to the left, correct?)
#### Post date: [May 14, 2024, 12:24pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/9 "2024-05-14T12:24:29Z")
</div>
yeah no issues with tagging. weirdly I just re-installed the 32bit version and i'm still getting the offset columns. hopefully you find a fix!
#### Post date: [May 14, 2024, 12:26pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/10 "2024-05-14T12:26:29Z")
</div>
Do you use a full Mp3tag installation or a portable version?
#### Post date: [May 14, 2024, 12:27pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/11 "2024-05-14T12:27:36Z")
</div>
I'm using the installation. Should I test with the portable version?
#### Post date: [May 14, 2024, 12:32pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/12 "2024-05-14T12:32:11Z")
</div>
Thanks for your offer, that's currently not necessary.
If I need some more informations, I let you know.
Please give me/us some time to investigate this behaviour. 😉
### Author: ![Florian](https://community.mp3tag.de/user_avatar/community.mp3tag.de/florian/32/5759_2.png) [@Florian](https://community.mp3tag.de/u/Florian)
#### Post date: [May 14, 2024, 2:54pm UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/13 "2024-05-14T14:54:56Z")
</div>
Thanks for reporting!
I've fixed the issue with [Mp3tag v3.25e](https://community.mp3tag.de/t/455). Please let me know if it works now for you.
#### Post date: [May 15, 2024, 12:04am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/14 "2024-05-15T00:04:11Z")
</div>
Thanks for the quick response, it works flawlessly now! 🙂
#### Post date: [May 15, 2024, 6:53am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/15 "2024-05-15T06:53:18Z")
</div>
Excellent! Thanks for confirming the fix.
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [June 14, 2024, 6:53am UTC](https://community.mp3tag.de/t/columns-for-tag-sources-with-cover-preview-are-offset-by-one-on-first-use/64678/16 "2024-06-14T06:53:28Z")
</div>
