Regarding the Tag Panel:
Is it possible to turn off the displaying of the Metadata on the Cover Art? It would be nice to have the Cover Art fill the entire area provided, rather the sizing down to display the metadata about the file (type, dimensions, file size, etc.)
A switch under the "View" menu for "Cover Art Metadata would be cool.
Thanks...
Double-clikc on the picture in the tag panel if you want to see it bigger - a new window will open.
The feature itself was introduced
[2020-12-16] NEW: added displaying image in Tag Panel and reading of dimensions and mimetype when listing image files.
Thank you
That works. I like the way the metadata is one line, at the top. Wish the primary cover window would display the data the same way.
Thanks.
