Digital Booklet iTunes
In iTunes, make sure you put a check mark in the menu option for View>Only Downloaded Items. Then you won't see these iCloud files any more. After you go through the preferences mentioned above, especially disabling iTunes from managing your library, you can manually add the folder(s) containing your music.
That’s very helpful, thanks
