# Filter Blank after Reapplying with Manage History
**URL:** https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758
**Category:** Fixed Bugs
**Tags:** bug-fixed
**Created:** [May 22, 2024, 11:13pm UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758 "2024-05-22T23:13:00Z")
**Posts on this page:** 6
**Page:** 1
<div class="post-metadata">
### Author: ![johnemc](https://community.mp3tag.de/user_avatar/community.mp3tag.de/johnemc/32/12312_2.png) [@johnemc](https://community.mp3tag.de/u/johnemc)
#### Post date: [May 22, 2024, 11:13pm UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/1 "2024-05-22T23:13:01Z")
</div>
I have a small bug to report. My filter is not displayed after I reapply the same filter through Manage History.
1. Select a saved Filter (via Filter drop-down or apply in Manage History).
 ![image](https://community.mp3tag.de/uploads/default/original/3X/0/3/0301dc8588361b0b4fa0104c37bd24c7f1780560.png)
2. Open Manage History (right arrow to the right of the Filter, then Manage history...)
3. Apply the same Filter (select same Filter, select Apply button).
 ![image](https://community.mp3tag.de/uploads/default/original/3X/f/a/fab708ae7abc1de3ddc326d1387929bc9db1d96b.png)
4. The result is a blank Filter:
 ![image](https://community.mp3tag.de/uploads/default/original/3X/d/e/de6901ca8fa090611843c29eade24d02bceea6d8.png)
I'm running v3.25h on Windows 11.
I do have a large number of filters, ~380
### Author: ![MotleyG](https://community.mp3tag.de/user_avatar/community.mp3tag.de/motleyg/32/440_2.png) [@MotleyG](https://community.mp3tag.de/u/MotleyG)
#### Post date: [May 23, 2024, 1:40am UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/2 "2024-05-23T01:40:32Z")
</div>
I can confirm this behaviour. For any saved filter, on first apply the filter is displayed in the box. On the second and any subsequent apply of the same filter, the box becomes empty. A new filter needs to be selected and applied to restore the expected behaviour.
### Author: ![anon32189785](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/a/45deac/32.png) [@anon32189785](https://community.mp3tag.de/u/anon32189785)
#### Post date: [May 23, 2024, 3:50am UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/3 "2024-05-23T03:50:08Z")
</div>
A simple **first workaround** would of course be to **save the filter** in **a text file** to have it handy for a **smart "copypaste"** thus avoiding the cumbersome retyping 😃
#### Post date: [May 23, 2024, 10:13am UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/4 "2024-05-23T10:13:50Z")
</div>
These filters are already saved in the managed list, so no retyping is necessary. Simply clearing the filter from the filter box first, then applying it again from the list works as the easiest workaround for now.
### Author: ![Florian](https://community.mp3tag.de/user_avatar/community.mp3tag.de/florian/32/5759_2.png) [@Florian](https://community.mp3tag.de/u/Florian)
#### Post date: [May 24, 2024, 9:53am UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/5 "2024-05-24T09:53:25Z")
</div>
This should be fixed with [Mp3tag v3.26](https://community.mp3tag.de/t/455). Thanks for reporting!
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [June 23, 2024, 9:53am UTC](https://community.mp3tag.de/t/filter-blank-after-reapplying-with-manage-history/64758/6 "2024-06-23T09:53:43Z")
</div>
