How to prepare settings for this bug [in version 3.16]
#1] Create some filtering expression; or make sure you have some existing ones
#2] Load many test files - don't try this on anything of value
#3] Left click in the box of filter
How to experience variant A:
#4] Move mouse pointer to the top file. [It does not have to be the one at the very top but it will be easier to evoke the bug]
#5] Start editing some tag field of that file - but do not accept the change yet
#6] Move pointer back over to the Filter box
#7] Start scrolling mouse wheel
#8] Choose whatever expression - but make sure that it will allow you to see at least one file in the main window
#9] Observe how the edited field stays floating like a ghost despite list of files in main windows is changing
#10A] Press Esc
to stop that bug that; or
#10B] Press Enter
to accept change of data
Result: edited data from tag field of another file gets saved in the current top-file, while that original file stays untouched
Possible additional outcome: sometimes it may be impossible to undo changes with CTRL + Z
[happened to me only once]
How to experience variant B:
#11] Move mouse pointer somewhere near the bottom of the list
#12] Start editing some tag field of some file - but do not accept the change yet
#13] Move pointer back over to the Filter box
#14] Start scrolling mouse wheel
#15] Choose whatever expression - but make sure that it will allow you to blank space [.i.e. lack of files] near the bottom
#16] Observe how the edited field stays floating like a ghost despite list of files in main windows is changing
#17A] Press Esc
#17B] Press Enter
Result: no data changes but you get a reward in form of a pop-op window with error message, as Mp3tag apparently just tried to edit tag field of file made of anti matter
Explanation:
a] Filter box does not take notice of user editing a tag field
b] Filter box does take notice of user editing a tag field - but is unable to cancel editing mode
c] Filter box allows for change of filtering expression - which should not be happening because Filter is suppose to be in some sort of temporary state of suspension
