Filtering by missing tag or null contents?
Is it possible to load a directory tree and have mp3tag filter all files where a tag is missing/null eg show me all files without a COMPILATION tag set?
Load the files as usual, press F3 to use the filter, select COMPILATION as field, use .+ as filter and check the box at the far right side of the filter to invert.
