freedb | Utils | Suggest sorting - title
#1
Can anyone tell me how to get this to work? I have say an album with titles in only filenames, and expect this feature to sort the files on the right so the titles match the freedb titles on the left. But it doesn't.
Thanks.
BTW, unticking is faulty - if Length is ticked, unticking Title does not go back to the same ordering.
"Suggest sorting - title" inaccurate
#2
Anyone, please? If the problem description is unclear, I can post an example.
#3
I've re-implemented the algorithm behind suggest sorting with the latest Development Build :slight_smile:
Best regards,
Florian
#4
...> [2006-11-04] REL: VERSION 2.37 (for Windows 2000/XP/2003/Vista)
...> [2006-10-06] CHG: re-implemented 'Suggest sorting - Title' at the freedb dialog.
Now works great! Thanks.
