Haha, I already expected such a comment
You know, the coin always has another side. If a tool does what I want it to use for, and it does it simply and reliably, it can be any old, I don't care. In other words, I don't see any problem using a software just because it is considered obsolete or outdated, by others (BTW: "decades old" means several ten years old - when actually did XP come out?
Why should I burn excess resources (like x-core processor GB ram super PC-s with W10 for example) for just to run a jukebox that as all features I needed, no less no more? That can run on a "decades old" PC, that would have been trashed anyway.
What do you use, when you need to drive in a simple screw? The latest, coolest, top notch, LiIon battery, computer-controlled torque, Makita, DeWalt, whatsoever power drill driver? That's nice, but I am 100% happy using my simple screwdriver, that is probably already 40 years old now. And I can even control the torque by my wrist
Yes, this piece of software is not supported (by the author, I guess you meant that way) any longer, but this piece of fact does not prove if it was crap or if it was not capable. I identified two shortcomings, for what there is an acceptable workaround, fair enough.
But back to the thread, I learned a lot during past few days, so thanks for your contribution.
