How to add custom Genre?
Alright. Do you know what other genres have the "hip" in them ?
You can use any text you think would be unique to identify it. But almost every example will find an exception. That’s why I suggest the filter option first, so a quick visual inspection lets you check for any rarities that should also be removed.
Hmmmm.......interesting.
I don't know anything about the filters. Will consider what to do with it later, in the meantime thanks to @LyricsLover and @MotleyG fo bringing this to my attention.
You people are awesome.
Quick answer for your question:
Hip House
and as part of a word also in
Praise & Worship
Hiplife
Chiptune
Just check the various online sources like this
The prior use of a Filter is most helpful.
See the documentation on filters:
I found
Alternative Hip Hop
Hip House
Trip Hop
