# How to get title & track number in 'title' field?
**URL:** https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437
**Category:** Support
**Created:** [November 28, 2009, 2:12pm UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437 "2009-11-28T14:12:11Z")
**Posts on this page:** 5
**Page:** 1
<div class="post-metadata">
### Author: ![hector896](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/h/a88e57/32.png) [@hector896](https://community.mp3tag.de/u/hector896)
#### Post date: [November 28, 2009, 2:12pm UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437/1 "2009-11-28T14:12:11Z")
</div>
Hi
I am using a creative Zen Vision M for my audio-books. The Zen sorts via the 'title' field. As audio-books, especially unabridged ones, are lengthy it greatly assists navigation if the title and track number is included in the title tag.
For example _'The Invisible Man Pt 01 - 001'_
I have set the 'Title' field in MP3 tag so that it displays in MP3 Tag in the title field as:
_'The Invisible Man Pt 01 - 01/87'_
By using '_%title% %track%'_ in the 'value' field for title
The problem I have is that when I transfer the audio-book to the Zen the title only shows
_'The Invisible Man Pt 01'_
I previously used foobar and managed to get title and track number in the title field on the Zen, but I find MP3 Tag, apart from this issue, easier to use.
I would be grateful for any suggestions as to what I am doing wrong.
Thanks
### Author: ![dano](https://community.mp3tag.de/user_avatar/community.mp3tag.de/dano/32/6_2.png) [@dano](https://community.mp3tag.de/u/dano)
#### Post date: [November 28, 2009, 2:33pm UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437/2 "2009-11-28T14:33:01Z")
</div>
I assume you changed a column in the file view, but this does not change your tags, it only changes what Mp3tag (one word) displays.
I suggest to revert this change.
To add the track number to the title tag create a [new action](https://community.mp3tag.de/t/967/1):
_Action type:_ **Format value**
_Field:_ **TITLE**
_Format string:_ **%title% %track%**
#### Post date: [November 28, 2009, 3:24pm UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437/3 "2009-11-28T15:24:36Z")
</div>
That's great thanks dano - have tried it and I now have the track numbers in the title field. Spent ages trying to work this out...................many thanks for your help 😃
### Author: ![redo](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/r/f9ae1b/32.png) [@redo](https://community.mp3tag.de/u/redo)
#### Post date: [November 29, 2009, 6:07am UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437/4 "2009-11-29T06:07:10Z")
</div>
I thank hector896 for starting this topic, as I had the exact same problem. I'm totally unfamiliar with Action, I thought the way to do it would be tag-tag conversion. Since this feature doesn't exist, I've resorted to entering the numbers manually.
I still find Action scripts daunting. Maybe I need a dummy's guide. 🙂
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:21pm UTC](https://community.mp3tag.de/t/how-to-get-title-track-number-in-title-field/9437/5 "2026-02-09T12:21:59Z")
</div>
