# Include 32-bit context menu in x64 package to serve BV6
**URL:** https://community.mp3tag.de/t/include-32-bit-context-menu-in-x64-package-to-serve-bv6/61704
**Category:** Support
**Created:** [July 30, 2023, 11:52pm UTC](https://community.mp3tag.de/t/include-32-bit-context-menu-in-x64-package-to-serve-bv6/61704 "2023-07-30T23:52:23Z")
**Posts on this page:** 3
**Page:** 1
<div class="post-metadata">
### Author: ![1024mb](https://community.mp3tag.de/user_avatar/community.mp3tag.de/1024mb/32/5653_2.png) [@1024mb](https://community.mp3tag.de/u/1024mb)
#### Post date: [July 30, 2023, 11:52pm UTC](https://community.mp3tag.de/t/include-32-bit-context-menu-in-x64-package-to-serve-bv6/61704/1 "2023-07-30T23:52:23Z")
</div>
When the x64 bit version of the program is installed it seems it only installs the 64-bit context menu.
I use XYplorer, which is a 32-bit application because it's written in BV6, so it obviously shows the 32-bit context menu. If I install the x86 build the context menu works well, but with the x64 build the context menu option doesn't show up, can you please include the 32-bit context menu in it?
Btw, all this in Windows 10.
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [July 31, 2023, 6:23am UTC](https://community.mp3tag.de/t/include-32-bit-context-menu-in-x64-package-to-serve-bv6/61704/2 "2023-07-31T06:23:09Z")
</div>
AFAI know, such specialities of non-standard file managers usually have to be dealt with in the support of that file manager.
E.g. like for Total Commander:
> [@No context menu at Total Commander](https://community.mp3tag.de/t/no-context-menu-at-total-commander/61338):
> Hi! i use totalcommander, and when i use the context menu in select files total it dosen't show the context menu. I added a shorcut of mp3TAG in total but it wont working properly i want open just selected files,but it opens all the files in the folder when i click the shortcut May u help me?
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:30pm UTC](https://community.mp3tag.de/t/include-32-bit-context-menu-in-x64-package-to-serve-bv6/61704/3 "2026-02-09T12:30:07Z")
</div>
