Is there a way to let mp3tag read an unknow mp3 tag?
Hi
is there a way to let mp3tag read an unknow mp3 tag?
for example RVAD or RVA2 for mp3 ?
or itunes TCMP means iTunes Compilation
thanks
This field can be read already, see
https://help.mp3tag.de/main_tags.html
This two tags are not "unknown":
RVAD is the id3v2.3 tag for "Relative volume adjustment"
RVA2 is the id3v2.4 tag for "Relative volume adjustment"
But, as @ohrenkino already wrote, both tags are currently not supported by Mp3tag.
You can find the detailed description in this document
https://id3.org/d3v2.3.0
just search for "4.12. Relative volume adjustment"
hi
but is there a way to let mp3tag to read them ?
for example config -> tags ->mapping ?
thanks
No, no way. I assume you could have guessed by now.
hi @ohrenkino
thank you so much!
