Itunes Rating
Hi all,
I registered only for that question. Have you even thought about creating a rating tag that can be compatible with Itunes under Pc or mac ?
I can ensure you, that would be very usefull or have I missed something ?
Thank you for your further answer !
Bioman
I think that this is an iTunes problem:
iTunes does not read rating fields.
iTunes does not write rating fields.
Regardless whether they are there or not. iTunes stores the ratings in the local itunes database.
