# iTunes tags in M4a being removed on edit with v3.27
**URL:** https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670
**Category:** Fixed Bugs
**Tags:** bug-fixed
**Created:** [August 20, 2024, 11:23am UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670 "2024-08-20T11:23:33Z")
**Posts on this page:** 8
**Page:** 1
<div class="post-metadata">
### Author: ![elis](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/e/e19b73/32.png) [@elis](https://community.mp3tag.de/u/elis)
#### Post date: [August 20, 2024, 11:23am UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/1 "2024-08-20T11:23:33Z")
</div>
Similar to [this fixed 2019 issue](https://community.mp3tag.de/t/some-itunes-tags-no-longer-working-with-v2-92/44312), since updating from v3.26 to v3.27, the iTunes `ITUNNORM` and `ITUNSMPB` tags are no longer shown in the extended tags window.
They're also removed when making other changes to tags - luckily I did have backups! 😅
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [August 20, 2024, 2:49pm UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/2 "2024-08-20T14:49:33Z")
</div>
I just created COMMENT ITUNNORM in this file and edited a number of other fields ...
 ![grafik](https://community.mp3tag.de/uploads/default/original/3X/2/1/213ac002d119b437d2f6093c4bd027ae42691c3a.png)
and the field COMMENT ITUNNORM is still there, even after repeated opening, editing and closing the file.
#### Post date: [August 20, 2024, 4:00pm UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/3 "2024-08-20T16:00:58Z")
</div>
Sorry, I should’ve been more specific - this seems to be an issue only with .m4a (MP4) files. `COMMENT ITUNNORM` is the MP3 equivalent and still works fine for MP3s.
### Author: ![Florian](https://community.mp3tag.de/user_avatar/community.mp3tag.de/florian/32/5759_2.png) [@Florian](https://community.mp3tag.de/u/Florian)
#### Post date: [August 21, 2024, 1:29pm UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/4 "2024-08-21T13:29:12Z")
</div>
Thank you for reporting this issue. Can you try this version and let me know if this fixes the issue for you?
[https://download.mp3tag.de/mp3tagv327a-x64-setup.exe](https://download.mp3tag.de/mp3tagv327a-x64-setup.exe)
#### Post date: [August 21, 2024, 2:08pm UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/5 "2024-08-21T14:08:18Z")
</div>
Yep, looks like it’s fixed with v3.27a. Tried tag editing, removal, and creation and everything worked well. Thank you for the speedy fix!
#### Post date: [August 21, 2024, 2:16pm UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/6 "2024-08-21T14:16:19Z")
</div>
Excellent — Thank you! I've just released an [official version Mp3tag v3.27a](https://community.mp3tag.de/t/mp3tag-v3-27-released/65520/4) including the fix.
#### Post date: [September 2, 2024, 9:25am UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/7 "2024-09-02T09:25:05Z")
</div>
A post was split to a new topic: [Cannot drag mp4 files onto MP3tag under Win 11](https://community.mp3tag.de/t/cannot-drag-mp4-files-onto-mp3tag-under-win-11/65805)
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [October 2, 2024, 9:26am UTC](https://community.mp3tag.de/t/itunes-tags-in-m4a-being-removed-on-edit-with-v3-27/65670/8 "2024-10-02T09:26:03Z")
</div>
