# Library not working?
**URL:** https://community.mp3tag.de/t/library-not-working/42706
**Category:** Support
**Created:** [August 20, 2018, 6:50pm UTC](https://community.mp3tag.de/t/library-not-working/42706 "2018-08-20T18:50:09Z")
**Posts on this page:** 9
**Page:** 1
<div class="post-metadata">
### Author: ![ianc911](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/i/9fc348/32.png) [@ianc911](https://community.mp3tag.de/u/ianc911)
#### Post date: [August 20, 2018, 6:50pm UTC](https://community.mp3tag.de/t/library-not-working/42706/1 "2018-08-20T18:50:09Z")
</div>
Hi there,
I've been using MP3Tag quite a bit and like it very much. Yesterday I upgraded to V2.89a and decided to enable the library feature, which as I understand it, is supposed to store the tags from a given file structure in a DB file to speed startup times.
I went ahead and enabled the feature on my library folder, which contains ~16K MP3's and it took a considerable amount of time to process. I noticed after a couple subsequent restarts that loading times were much faster.
After hibernating the machine yesterday, I find that load times are back where they were prior to enabling the feature however, and it's taking over 5 min. each time to start. I see that the DB file has been created, and it's about 65 MB in size, but it doesn't seem as though it's actually doing anything now.
The machine is Win10 1803, an i7-4790 with 16 GB of RAM. The library is on D:\ (a spinning disk), and the DB is on C:\ ( a 512 GB SSD).
Am I misinterpreting the function of the library function? Should the startup time not decrease after enabling it? Thanks for any help,
ianc
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [August 20, 2018, 7:54pm UTC](https://community.mp3tag.de/t/library-not-working/42706/2 "2018-08-20T19:54:52Z")
</div>
The library feature is mainly to maintain also large collections, usually more than 80k of files.
A speedier initial phase is not the primary target and actually an indication that tagging is not really necessary as nothing has changed.
If you load new files, then it will probably take as much time as before as each new file has to be read for the first time.
#### Post date: [August 20, 2018, 8:34pm UTC](https://community.mp3tag.de/t/library-not-working/42706/3 "2018-08-20T20:34:39Z")
</div>
Hmmm... The docs say:
"On subsequent reads of the file, the metadata is read directly from the database and updated if the file's modification timestamp has been changed."
If it doesn't speed load times and lessen the processing time of all those files, I guess I'm not really seeing the point of it then? Should I just disable the feature and reclaim the 65 MB? I was kind of hoping it would lessen the 5 min loading time...
ianc
### Author: ![ryerman](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ryerman/32/5285_2.png) [@ryerman](https://community.mp3tag.de/u/ryerman)
#### Post date: [August 20, 2018, 10:36pm UTC](https://community.mp3tag.de/t/library-not-working/42706/4 "2018-08-20T22:36:15Z")
</div>
> [@ianc911](#):
> .....If it doesn't speed load times and lessen the processing time of all those files.......
It does on my system.
I just loaded 26,000 files in less than 30 seconds.
Make sure the Library is enabled, like this:
 ![EnableLibrary](https://community.mp3tag.de/uploads/default/original/2X/a/a42ef0436f83e5eecf5b570abcd4356717706bff.png)
#### Post date: [August 20, 2018, 11:39pm UTC](https://community.mp3tag.de/t/library-not-working/42706/5 "2018-08-20T23:39:10Z")
</div>
Yep, got it set up properly I believe:
![image](https://community.mp3tag.de/uploads/default/original/2X/d/da5cc5cc42ee79ab8dd7fdbaeb6e360074a20294.png)
Well, the behavior has been erratic so far. I'll continue to monitor it..
ianc
#### Post date: [August 21, 2018, 1:42am UTC](https://community.mp3tag.de/t/library-not-working/42706/6 "2018-08-21T01:42:15Z")
</div>
> [@ianc911](#):
If problems continue, you could install **[V2.89b](https://community.mp3tag.de/t/mp3tag-development-build-status/455)** and/or delete **mp3tag.db3** and then remake the library.
#### Post date: [August 21, 2018, 4:36pm UTC](https://community.mp3tag.de/t/library-not-working/42706/7 "2018-08-21T16:36:55Z")
</div>
OK, the repeat-open performance yesterda was pretty good as long as the machine had not been shut down (ie. expected caching behavior).
I hibernated the machine again last nite and upon starting it this AM, was back to the 5+ min loading time again.
I'll try disabling the library, removing the DB file and letting it regenerate, then move on to 2.89 b or c if no luck. Thanks for the suggesitons and stay tuned!
ianc
#### Post date: [August 24, 2018, 4:25am UTC](https://community.mp3tag.de/t/library-not-working/42706/8 "2018-08-24T04:25:23Z")
</div>
Removed the DB and let it rebuild. Same behavior. Now when I try to cancel the 'Reading Directory; dialog on startup, it crashes.
I don't really want to go through the rigarmarole of installing the b & c versions, then retesting after shutdown, startup, etc. For me, at any rate, the library function is broken, so I'll just disable it.
Thanks for the help,
ianc
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:27pm UTC](https://community.mp3tag.de/t/library-not-working/42706/9 "2026-02-09T12:27:36Z")
</div>
