@incifinci
The "NO" option is the desired behavior. As far as this bug report, at least 2 see a fix. Good.
I read your other thread and earlier posts here and it seems that you also experience the same "focus shift to first column" after an "Undo" with Tag Panel visible. I don't know if that is the desired behavior, however, I have the same experience when using v3.4.2.2.
@Florian Note that when Tag Panel is not visible, and changes are made via Extended Tags followed by Undo, there is no jump. (I almost never use Tag Panel, takes up too much space.)
I've just uploaded another internal version (3.4.2.3) with lots of changes that hopefully address the described issues with scroll after save by click and undo.
It seems, you did it, Florian. I tried everything difficult on 230 mp3 files; in both of clean mobil and usual (with existing config) setup: no jumps to the left. And i did not notice anything other changed behavior.
A couple days on 3.4.2.2 and a couple on 3.4.2.3, and no adverse effects.
I did test for incifinci's indicated issues and they seem resolved here as well.
