Menu Icon Alignment
Small thing, but new menu icon does not align correctly in Win 7.
See here: https://i.imgur.com/B28Ncod.jpg
It's an outdated OS, so I'd understand if you skip this. But, if easy, please consider "fixing". Thanks.
This is what the remote picture looks like
undefined - Imgur
This is what it looks like on my W7:
contextmenu
Looks ok to me ...
My Windows 7 test system also shows the icon as depicted in @ohrenkino's version of the screenshot with correct alignment and the extra vertical line separating the icons from the menu item texts.
