@ milka:
You do some really good export files. They are a great inspiration for the one I'm working on.
Finally fixed very big bug with expanding albums in Artist-Album Tracking Full.
You must download new updates.
I have the probelm that when the symbol "#" is in the folder path that I can't see the album cover. This is a problem I have with all of your export files. I use the "#" symbol for artists, of which the first character is a digit (e.g. 36 Crazyfists or The 69 Eyes)
Thats not my fault. I test it, tag in html doesnt support # as first char (I dont know why).
Example:
Yeah, you can't use "#". But you can use "%23" in place of it in the HTML.
Two symbols are forbiden in src="folderpath/cover.jpg":
at the begining of folder or cover name (you can use %)
- ' anywhere in folder or cover name (you can use ยด)
OK. I didn't know that. Thanks milka and Psiphon for the informations. ![]()
Updates again in Artist-Album Tracking Exports.
Updates again!
Removed blank lines, what reduce size of created html file.
Check out on first page of this topic.
New export.
Beta version.
Finished new Mp3tag Export!
Renamed Artist-Album02_m3u (check updates).
Great script.
But a little slow. The thing with the lyrics is a great idea. And also the script that only shows one data-set is great. But I know it from somewhere. ![]()
I'm glad that I was able to inspire you on this.
Thanks very much, what is slow?
I updated Mp3tag export. You must download this update!
I am working very hard on all exports, soon they will all be fixed from bugs and improved.
~ milka
I just improved the script. I found two unneeded array fields.
Thanks, for your help with code. ![]()
Something is wrong while you renamed arrays (popup win is not working).
I fix it and updated Mp3tag export.
I have change names of all exports and help files, it's strongly recomanded to read help files (steps in example) before exporting ! ! !
Many bug fixes and more. Check out updates on first page of this topic.
Added new export.
I removed new export conf. (PDF covers) becase I hate complicated converting latex to pdf. I will make covers for printing in html.
Finished new export for printing covers in html.
Check out.
With updates to perfection.
