# Mp3tag does not distinguish between images of the same size (in pixels and bytes)
**URL:** https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602
**Category:** Fixed Bugs
**Tags:** bug-fixed
**Created:** [October 2, 2021, 4:17pm UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602 "2021-10-02T16:17:55Z")
**Posts on this page:** 6
**Page:** 1
<div class="post-metadata">
### Author: ![incifinci](https://community.mp3tag.de/user_avatar/community.mp3tag.de/incifinci/32/6526_2.png) [@incifinci](https://community.mp3tag.de/u/incifinci)
#### Post date: [October 2, 2021, 4:17pm UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/1 "2021-10-02T16:17:55Z")
</div>
As in the title. Here are the image files:
 ![front 1](https://community.mp3tag.de/uploads/default/original/2X/6/682fa4d56125b1e9c7e0a7fe399ba7f260482487.jpeg)
 ![front 2](https://community.mp3tag.de/uploads/default/original/2X/a/a85361df0c2ca91d80625f1790468a35b80e914e.jpeg)
The sizes in pixels and bytes are identical. They are embed in 2 FLAC files (44.1/16), but then i tried it with 2 mp3 files as well. The result is the same. Selected both file: image viewer in both Tag Panel and Extended Tag Panel shows the first image (depending on the order in the list), instead of NOT showing image, with text "Cover varies".
There are additional diagnostic options, but i am more interested in the experience of others. Or if Florian ask for something.
Hmm... The forum motor resizes the images. Here are the originals:
[front 1.jpg](http://users.atw.hu/eger-hajduhegy/front%201.jpg)
[front 2.jpg](http://users.atw.hu/eger-hajduhegy/front%202.jpg)
### Author: ![ryerman](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ryerman/32/5285_2.png) [@ryerman](https://community.mp3tag.de/u/ryerman)
#### Post date: [October 2, 2021, 5:26pm UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/2 "2021-10-02T17:26:50Z")
</div>
I see the same behaviour.
It seems that Mp3tag uses size and dimension to compare covers, but not content.
### Author: ![Florian](https://community.mp3tag.de/user_avatar/community.mp3tag.de/florian/32/5759_2.png) [@Florian](https://community.mp3tag.de/u/Florian)
#### Post date: [October 6, 2021, 5:19am UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/3 "2021-10-06T05:19:40Z")
</div>
I think I've used this as a performance tweak, where I use the amount of covers in the files as first criteria and the size in bytes as second criteria (only if all selected files have the same amount of covers). I knew it wasn't 100% correct, but secretly hoped this day with this bug report would never come.
Comparing content would make this comparison always necessary, e.g., for albums where each track has the same cover. I'll look into it again.
#### Post date: [October 6, 2021, 10:28am UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/4 "2021-10-06T10:28:12Z")
</div>
I do not know, how long Mp3tag handles images. Anyway, i have been using it for 15 years, often, and this is the first such case, as i remember.
#### Post date: [October 9, 2021, 12:52pm UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/5 "2021-10-09T12:52:32Z")
</div>
It's fixed with [Mp3tag v3.10a](https://community.mp3tag.de/t/455).
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [November 8, 2021, 12:52pm UTC](https://community.mp3tag.de/t/mp3tag-does-not-distinguish-between-images-of-the-same-size-in-pixels-and-bytes/54602/6 "2021-11-08T12:52:58Z")
</div>
