No explorer context menu integration
I did a registry search for remaining lines with mp3tag in the registry after the uninstall of 3.11 and then deleted them.
After that installed 3.07 instead of 3.11. The older version works.
I've tried re-installing 3.11 and it doesn't give me the explorer right click feature.
3.07 does when I re-install it.
I'll wait for 3.12 and then try again.
I guess you didn't answer the question: are you using the new context menu of Windows 11 or did you apply any registry tweaks to get the old context menu back?
@firedog: It's about the new registry key {86ca1aa0-34aa-4e8b-a509-50c905bae2a2} as you can find it here:
I'm not using registry tweaks. I'm getting the context menu in Windows 11, but only if I install 3.07 instead of 3.11.
With 3.11 I don't get it.
