Noob questions on interface
#1
I recently upgraded from v2.39 to v2.40 - I have two areas that I need help with and hopefully someone can assist.
I notice that the "Tag to Filename" function now requires user confirmation where I am positive that in v2.39 the confirmation dialogue box could be turned off. Am I missing something or is this by design ? Can it be automated through an Action ?
Is it possible for any of the extended tags (for example Language, Copyright) to be assigned default values as per standard tag panel (every time application is started not per tag session) ?
Hope someone can help or put me right if I am being a fool !
Thanx in advance people
#2
This has been changed and it can't be turned off in Mp3tag v2.40. You can use an action Format value for _FILENAME to automate this task.
Unfortunately not.
Kind regards,
Florian
#3
Thanks Florian
I assume I use the Replace action with _FILENAME as the field, should i be using %artist% - %title% as the replacement syntax ? And what do I use as the "original"
#4
Ignore that last comment - I worked it out.
Thanks again
#5
As workaround I would make Format value actions that fill these tags with your preferred values.
The finished actions are also available as drop down list so it's just two clicks.
#6
Can format values be combined to rewrite mulitple fields at once ?
I'll give it a try in the meantime to see if I can work it out - thanks Dano
