I pressed File>Remove Tag (Ctrl+R) and removed tags.
Then freshly typed tags and copied to my phone. Amazingly it worked!!!!
After all, I added album artwork (size 300x300, 55.6 kb, created with photoshop cs 5) to this album and freshly copied to my phone (previous one delected). Then the problem remained same. Not showing particular details!
Then I removed Album Artwork from my album and freshly copied to my phone. No use. Its not showing above discussed details.
In these trials I used "ISO-8859-1". ('UTF-16' was completely not useful.)
I am not understanding exactly what happening, but now I am suspecting on second time saving of my album with Mp3Tag.
Sorry you did break the currently test scenario while supporting you with our remote help.
I am glad that you partly got new insights.
The description of the new test conditions sounds as the problem has nothing to do with Mp3tag.
I recommend that you get an account in the NOKIA user group and ask your questions over there.
The problems seem to be hardware resp. firmware related.
Ask for the allowed image type, the maximal size of the embedded cover image, the allowed tag type, the allowed character set, and so on.
Ask them to update their user manual.
Good luck!
May be your also correct.
But images (Album Artworks) showing properly in my device. Other albums converted other than MP3Tag also showing the details correctly. So how can I ask NOKIA about my problem?
Now I decided to go as it is.
Thank You DetlevD for your kind help here and through out this forum.
