Remove duplicate data and sort data within a single field
I am trying to write an action group focusing on the field (%CONTENTGROUP%). The field contains particular values separated by spaces (possible more than one), which I use to create smart folders in itunes. The existing values are:
$-$5 ($+single number. may not contain a number)
!-!5* (!+single number. may not contain number. may contain a trailing *)
A-Z (single capital letter)
[1]-[5] (single number in brackets. may be duplicates)
{A}-{Z} (single capital letter in braces. may be duplicates)
(Ax)-(Zy) (double capital letters in parentheses)
(single #. may be duplicates)
Some hypothetical examples:
ex1: $ [1] # [3] T [1] A {S} !2* [1]
ex2: !2 $3 [4] [2] [4] # (JU) {S} {P} {P} #
ex3: $1 ! [3] {S} (TT) # [1] [3] {P} T {B}
I would like to do the following with the action group:
START
  1. Remove any duplicate "words", single "symbols" and single letters.
  2. Sort the data within the field in this order:
$number (ascending)
!number (ascending)
Single LETTER (alphabetical)
[number] (ascending)
{LETTER} (alphabetical)
(Double LETTER) (alphabetical)
  1. Remove extra spaces
    FINISH
The desired results for my examples would be:
ex1: $ !2* A T [1] [3] {S} #
ex2: $3 !2 [2] [4] {P} {S} (JU) #
ex3: $1 ! T [1] [3] {B} {P} {S} (TT) #
I could use the following for the extra space removal, but I'm not sure whether it should run first or last:
START
Replace reg expression
CONTENTGROUP
^\s+
(leave blank)
CONTENTGROUP
\s+$
(leave blank)
CONTENTGROUP
\s{2,}
(single space)
FINISH
As far as the sorting and duplicate removal goes, I'm stumped.
Any help creating this would be most appreciated!
Well, to make your crazy adventure a short story ...
ad 1: Search the forum for a method using regular expression to remove duplicate items from an item list, there is one buried in the forum posts in the last one or two years.
/t/10616/1
ad 2: Mp3tag provides no sort method for text strings in the format of a delimiter separated item list.
ad 3: Already solved by yourself.
Maybe you can solve the processing of the complex contentgroup scheme by dividing the complex value into some dedicated helper tag-fields, so that each helper tag-field carries one set of data type, which possibly can be processed by Mp3tag functions.
DD.20121108.1645.CET
