Remove numbers or other charecters from a field
Hi. I have a problem that's been driving me crazy. I've tried for hours and searched here and google and nothing I've found has worked for me.
I am trying to remove numbers and/or charecters from a field, such as title. For example:
TITLE:
05 - Crazy
to
Crazy
or
05 Crazy
to
Crazy
I use the quick action REPLACE and select the field (in this case TITLE).
None of the codes I've found work in removing the numbers or dashes.
Any help would be appreciated. Thanks.
MP3Tag v2.81
You need to use replace with regular expression and use on the TITLE with:
Replace: ^\d*\s*-\s
With: Leave Blank
have a similar problem, but it won't delete the track #.
Change Title
06 - Just For One Day - (Featuring: Imaani)
To read:
are need to create and action to delete leading 5 characters
Thanks
Try an action of the type "Replace with regular expression" for TITLE
Search string: (?-i)\d+ - (.*)
Replace string: $1
