Remove unwanted tags from filter dropdown
Is it possible to remove tags that I do not use from the filter dropdown and also add tags that I do use.
Thanks
How to add tag fields to the filer list:
  • Select a file, click View > :mt_tag: Extended Tags...
  • Click on :mt_new: and enter the field name you want to add to the filter, also enter some value
  • Click OK twice and exit Mp3tag
How to remove tag fields from the filer list:
  • Click on :mt_new: and select the field name you want to remove
  • Press SHIFT + DEL
  • Now select a different field and enter some value
It is planned to improve this procedure.
Great!
Thank you very much Dano
Is it still same procedure or has any improvement been done?
Nope, this is still the current (and admittedly very tedious) way of adding/removing fields.
