REQUEST: Dark Theme
hi
could be implemented for w7 too?
i would like it a lot
thanks Florian
@rama You ask for new features for a no more supported OS?
After January 14, 2020, PCs running Windows 7 no longer receive security updates. Therefore, it's important that you upgrade to a modern operating system such as Windows 10, which can provide the latest security updates to help keep you and your data safer. In addition, Microsoft customer service is no longer available to provide Windows 7 technical support.
Hi
yes i know there is no more support , i did pay for w7
I still run on a laptop
if it could added it's welcome ...
thanks
Support this feature! Make the ability to choose a light theme!
I also don't like the 'Dark Mode', and I want the option to revert to 'Light Mode'.
The other way to achieve this, is to install MP3Tag v3.08 again (the version without dark mode) :slight_smile:
I've added an option to choose color mode between dark, light, and default with Mp3tag v3.09a. Please test thoroughly, I plan to release an official version soon.
What's the difference between Dark & Default?
Default = like surrounding Windows theme
Dark Mode and Default (w Windows 10 Dark Mode) are really great - congratulations on a big feature improvement.
One request:
The main window highlight color for selected tracks (or selecting All with Control-A) is a very dark blue which makes it difficult to distinguish between selected and unselected tracks. Please increase the contrast for selected tracks a little bit.
NOTE 1: When you click in the tag panel, the background of selected tracks changes to medium brown/grey which is fine. I just would like a little more contrast in the blue color before clicking in the tag window.
NOTE 2: The bright outline box for the single last selected track does not solve the issue when multiple tracks are selected.
Thanks.
