Save tags not working
bug-awaiting-feedback
#1
after i save the tags they just dissapear, but i get the "saved tag" window, what can i do?
Change of genre
#2
Can you check whether you have any duplicate fields at "Options > Tag Panel"? If so, please remove the duplicates.
If not, can you check your tag settings at "Options > Tags > Mpeg" (assuming you're working with MP3) and uncheck APEv2 at "Read" and "Write".
#3
i don't have duplicate fields nor APEv2 checked, still not working :c
#4
Can you send me one of those files via email or Dropbox link?
#5
A post was split to a new topic: Problem when entering MusicBrainz IDs (e.g., MusicBrainz Artist ID)
