# Simple way to change all entries for single field
**URL:** https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369
**Category:** Support
**Created:** [April 29, 2010, 12:44am UTC](https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369 "2010-04-29T00:44:17Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![Big\_Al51](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/b/c0e974/32.png) [@Big\_Al51](https://community.mp3tag.de/u/Big_Al51)
#### Post date: [April 29, 2010, 12:44am UTC](https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369/1 "2010-04-29T00:44:17Z")
</div>
Hi
I've always used the convention of including the CD number in the album field for cd sets. Amazon provides the album name eg. My Album. I want to change the album field so that it becomes My Album - CD 1. Is there a simple way to achieve this without have to use cut and paste for each track?
For example is it possible to select just the album field (the whole column) and then update by changing the value in the album field on the tag panel?
Apologies if this is mentioned in FAQs, but again I looked and couldn't find it.
Thanks in advance for help and assistance.
Alan Shelton
### Author: ![DetlevD](https://community.mp3tag.de/user_avatar/community.mp3tag.de/detlevd/32/123_2.png) [@DetlevD](https://community.mp3tag.de/u/DetlevD)
#### Post date: [April 29, 2010, 3:59am UTC](https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369/2 "2010-04-29T03:59:09Z")
</div>
> [@Alan Shelton](#):
> ... I want to change the album field so that it becomes My Album - CD 1. Is there a simple way to achieve this ... For example is it possible to select just the album field ...
You can use Mp3tag "actions" feature.
[/t/967/1](https://community.mp3tag.de/t/967/1)
DD.20100429.0800.CEST
#### Post date: [April 29, 2010, 10:59pm UTC](https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369/3 "2010-04-29T22:59:35Z")
</div>
> [@DetlevD](#):
Thanks DetlevD. Works perfectly!
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:22pm UTC](https://community.mp3tag.de/t/simple-way-to-change-all-entries-for-single-field/10369/4 "2026-02-09T12:22:21Z")
</div>
