And if the desired display of DD-MM-YYYY is restricted for MP3Tag, the value of the column could be changed on the base of one of the many suggested expressions for sorting.
You have earned a point with this ohrenkino. I discovered that my Plex does not support dd-mm-yyyy. Does anyone have an idea for a faster way to convert the tag dd-mm-yyyy to the ISO 8601 format?
Select the files in which you want to rearrange the numbers.
Open Convert>Tag-Tag for RELEASETIME
Enter as format string
or
or
If you have executed one of the above commands, don't forget to remove the
Sort By: command in your column definition for Releasetime.
The "Sort by" is no more needed after your RELEASETIME content was changed to YYYY-MM-DD.
