# Spaces between letters
**URL:** https://community.mp3tag.de/t/spaces-between-letters/57223
**Category:** Support
**Created:** [May 6, 2022, 5:05pm UTC](https://community.mp3tag.de/t/spaces-between-letters/57223 "2022-05-06T17:05:45Z")
**Posts on this page:** 4
**Page:** 1
<div class="post-metadata">
### Author: ![MikeyMike75](https://community.mp3tag.de/user_avatar/community.mp3tag.de/mikeymike75/32/5652_2.png) [@MikeyMike75](https://community.mp3tag.de/u/MikeyMike75)
#### Post date: [May 6, 2022, 5:05pm UTC](https://community.mp3tag.de/t/spaces-between-letters/57223/1 "2022-05-06T17:05:45Z")
</div>
Hello all,
I have a question.
When tagging some mp3 files from Discogs I get strange titles:
    > J. Cole - a p p l y i n g . p r e s s u r e <
What I want is very simple, I hope.
The spaces between the letters and the changing of the 'space dot space' into a space.
I hope someone can help me with this.
In the meantime I am going to search for a sollution myself and maybe I find it and will share it here.
Thanks,
Mike.
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [May 6, 2022, 5:12pm UTC](https://community.mp3tag.de/t/spaces-between-letters/57223/2 "2022-05-06T17:12:11Z")
</div>
You could try:
`$replace($regexp($replace(' J. Cole - a p p l y i n g . p r e s s u r e ',. ,._),(.) ,$1),_, )`
### Author: ![ryerman](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ryerman/32/5285_2.png) [@ryerman](https://community.mp3tag.de/u/ryerman)
#### Post date: [May 6, 2022, 5:55pm UTC](https://community.mp3tag.de/t/spaces-between-letters/57223/3 "2022-05-06T17:55:45Z")
</div>
I tried several times at Discogs and did not get 'space dot space' in the results.
Please post a screen-shot of the "Adjust tag information" window that you used.
Also, tell us your settings here: Options \> Tags \> Mpeg
> [@Hints for asking Support Requests](https://community.mp3tag.de/t/hints-for-asking-support-requests/56190):
> If you need support using Mp3tag, you can help the community members that are about to support you in finding a solution or workaround to your problem, by following these simple guidelines. Be descriptive, also in what you’ve already tried Please give a short explanation what’s not working as expected or what you’re trying to achieve. It’s best to know any details about the problem at hand and especially, what steps you’ve already tried to solve it by yourself. Helpful information also includ…
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:29pm UTC](https://community.mp3tag.de/t/spaces-between-letters/57223/4 "2026-02-09T12:29:45Z")
</div>
