Tag Profiles for differant media types
Is it possible to create separate profiles for the type of media tagging? Example, I rip CDs for my music library. That uses one type of tags with tracks, etc.. I also record numerous radio shows that uses a different set of tag data. Based on what type of media I'm tagging, it would be nice to load a profile for the type of tag data needed for only the type of media. Now I have to adjust the Tag Field when I switch between CDs and recorded media.
Thanks
Chuck Dean
see e.g here:
You can save the current configuration.
You can rename that configuration (manually with the means of the explorer).
You can load a different, previously saved configuration that you rename to the standard name.
