# The Case Conversion Option ::: Title Case vs Mixed Case
**URL:** https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220
**Category:** Support
**Created:** [October 8, 2014, 8:37am UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220 "2014-10-08T08:37:47Z")
**Posts on this page:** 10
**Page:** 1
<div class="post-metadata">
### Author: ![ragtag](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ragtag/32/13146_2.png) [@ragtag](https://community.mp3tag.de/u/ragtag)
#### Post date: [October 8, 2014, 8:37am UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/1 "2014-10-08T08:37:47Z")
</div>
Hello Everyone
The Case Conversion option provides several ways to display the final sentence letter case. The one that I find lacking, is the **Title Case** , which requires the correct language case format. Although Mixed Case is close, it capitalizes every word in a sentence. Is it possible to provide an option, or script, for Title Case which closely follows the languasge rules?
**Here are some samples of the aforementioned Title Case:**
Rock 'n' Roll
Will o' the Wisp
Nowhere to Hide
How to Dismantle an Airplane
Songs I Love to Dance to
Reality Claimed to Be a Friend of Yesterday
Death Jump for Flyers
Pretty in Blue
Came in from the Cold
Love Is in the Air
I Am the Lonely One
That Was Then, This Is Now
You Are So Beautiful
This Is As Good As It Gets
I vs. Me
Thank you.
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [October 8, 2014, 8:50am UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/2 "2014-10-08T08:50:25Z")
</div>
> [@ragtag](#):
> ... Is it possible to provide an option, or script, for Title Case which closely follows the languasge rules?
These rules probably only apply to the English language, right? In German or French they would not be valid, I guess.
Have a look at this thread
[/t/15863/1](https://community.mp3tag.de/t/15863/1)
it might help.
#### Post date: [October 8, 2014, 9:02am UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/3 "2014-10-08T09:02:46Z")
</div>
Thank you, Ohrenkino. Yes, it applies to English.
#### Post date: [October 8, 2014, 2:57pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/4 "2014-10-08T14:57:21Z")
</div>
There has been a similar exercise with the "grammatron" conversion:
[/t/11684/1](https://community.mp3tag.de/t/11684/1)
#### Post date: [October 8, 2014, 3:17pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/5 "2014-10-08T15:17:56Z")
</div>
@Ohrenkino
I have installed the natural Mixed Case Extensions, but in setting up the mapping of the FLAC tag fields according to Nature's instructions, I need to know if it is best to delete the item highlighted in red:
> 1. Since the files are FLAC, Mp3Tag does not automatically map all tag fields, so you may have to do it manually to see them the way I do. To change it, go to Mp3Tag Menu \> File \> Options\> Tags | Mapping
> a) Here are the VorbisComments that I have set up to use with FLAC files:
> <b>Tag Source	Target[b]
> <!--coloro:red--><span style="color:red"><!--/coloro-->[b]VorbisComment	DATE Year (*)<!--colorc--></span><!--/colorc--></b>
> VorbisComment	ORGANIZATION	Publisher
> VorbisComment	TRACKNUMBER Track
> VorbisComment	SOURCE MEDIUM	MediaType
> VorbisComment	ORIGIN WEBSITE	WWWAudioSource
> VorbisComment	INITIAL KEY InitialKey
> (\*) I stopped using this mapping, since it created problems when using ID3v2.4 and also sometimes when converting from FLAC to Mp3. So now I work directly on the DATE field always (FLAC and MP3), since MusicBee automatically detects a full Date field and converts it to the ID3 weird two fields format.
> :sunglasses: After making these changes, you *must* close and reopen Mp3Tag.
> c) This way you will always see and use the same tag fields whether they are MP3 Files or FLAC.
I do not yet fully understand all the implications of what I am doing here, but I will test everthng once it is correctly set up.
Thank you for your pointing me in the right direction.
#### Post date: [October 8, 2014, 3:22pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/6 "2014-10-08T15:22:37Z")
</div>
Mapping the flac fields to mp3 fields is only necessary if you actually use flac files.
For mp3 tags no mapping is necessary. These are serviced by MP3tag.
#### Post date: [October 8, 2014, 4:14pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/7 "2014-10-08T16:14:37Z")
</div>
When you say "if you actually use flac files", do you mean as in play or tag them? My complete CD-collection has just been ripped to FLAC. I need to correctly tag them. Should I remove the first line **Vorbis Comment DATE Year**?
Could you please tell me too, if it is possible to move actions between groups, or do they have to be recreated anew?
Thanks.
#### Post date: [October 8, 2014, 5:04pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/8 "2014-10-08T17:04:34Z")
</div>
> [@ragtag](#):
> Thanks.
If you want to tag FLAC files, then I would think that you need the mapping list. I would not delete anything.
You cannot really move actions between action groups.
You can copy an action group and then continue to modify that group.
#### Post date: [October 9, 2014, 8:13am UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/9 "2014-10-09T08:13:58Z")
</div>
Thank you, ohrenkino 🙂
### Author: ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)
#### Post date: [February 9, 2026, 12:25pm UTC](https://community.mp3tag.de/t/the-case-conversion-option-title-case-vs-mixed-case/16220/10 "2026-02-09T12:25:18Z")
</div>
