# Title case
**URL:** https://community.mp3tag.de/t/title-case/12010
**Category:** General Discussion
**Created:** [May 14, 2011, 7:14pm UTC](https://community.mp3tag.de/t/title-case/12010 "2011-05-14T19:14:19Z")
**Posts on this page:** 15
**Page:** 1
<div class="post-metadata">
### Author: ![The\_Original\_Invisib](https://community.mp3tag.de/user_avatar/community.mp3tag.de/the_original_invisib/32/209_2.png) [@The\_Original\_Invisib](https://community.mp3tag.de/u/The_Original_Invisib)
#### Post date: [May 14, 2011, 7:14pm UTC](https://community.mp3tag.de/t/title-case/12010/1 "2011-05-14T19:14:19Z")
</div>
Does anyone know the expression to Title case words between brackets?
So that
Song Title (between brackets)
becomes
Song Title (Between Brackets)
Thanks
Lee
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [May 14, 2011, 7:19pm UTC](https://community.mp3tag.de/t/title-case/12010/2 "2011-05-14T19:19:34Z")
</div>
> [@The\_Original\_Invisible](#):
Create a user defined action of the type modify case
Set the mode to "Normal".
Enter as characters that define the delimiters between words at least a blank (space) and the opening bracket.
In addition you can enter any other character which serves as separator between words.
#### Post date: [May 14, 2011, 7:51pm UTC](https://community.mp3tag.de/t/title-case/12010/3 "2011-05-14T19:51:18Z")
</div>
> [@ohrenkino](#):
Brilliant! Thanks very much!!
By the way, I could only seem to do it for the field name \_ALL as couldn't find a field called "Title"
Tried it on"TRACK" but it didn't work
#### Post date: [May 14, 2011, 8:04pm UTC](https://community.mp3tag.de/t/title-case/12010/4 "2011-05-14T20:04:30Z")
</div>
> ... for the field name \_ALL as
Track describes the track number.
\_All modifies all tags including the pseudo tags like \_filename - there was once an issue when modifying mp3 to Mp3 or even MP3 as the suffix caused havoc in the filesystem.
Press the arrow-button in the dialogue to get a list of available tags. "Title" should be among them (do update to the latest version - earlier versions did not have the Title in all of these selection lists).
#### Post date: [May 14, 2011, 8:15pm UTC](https://community.mp3tag.de/t/title-case/12010/5 "2011-05-14T20:15:02Z")
</div>
> [@ohrenkino](#):
Just upgraded to 2.48 and TITLE not in the drop down list for the action case conversion?
#### Post date: [May 14, 2011, 8:19pm UTC](https://community.mp3tag.de/t/title-case/12010/6 "2011-05-14T20:19:30Z")
</div>
That is really strange - what kind of file- and tag-format do you have?
(I am not very good at flac ...)
#### Post date: [May 14, 2011, 8:24pm UTC](https://community.mp3tag.de/t/title-case/12010/7 "2011-05-14T20:24:18Z")
</div>
> [@ohrenkino](#):
Just normal mp3s. Tag format? Not sure what you mean by that, sorry!
#### Post date: [May 14, 2011, 8:30pm UTC](https://community.mp3tag.de/t/title-case/12010/8 "2011-05-14T20:30:28Z")
</div>
OK - as tag formats there is v1, v2.3 and APE.
APE usually only causes trouble ...
But this should no affect the display of the program ... now I am at my wits end.
(all the other tags like artist, albumartist, albumsort etc are there, right? Only title is missing ..? Haven't got a clue)
#### Post date: [May 14, 2011, 8:36pm UTC](https://community.mp3tag.de/t/title-case/12010/9 "2011-05-14T20:36:50Z")
</div>
> [@ohrenkino](#):
Yeah the drop down starts
\_ALL
\_DIRECTORY
\_FIELDNAME
\_FILENAME
\_TAG
\_ALBUM
etc
Must be at least 70 options, but not TITLE!
If it can't be done, it can't be done. Thanks for your help with this anyway! Much appreciated
### Author: ![DetlevD](https://community.mp3tag.de/user_avatar/community.mp3tag.de/detlevd/32/123_2.png) [@DetlevD](https://community.mp3tag.de/u/DetlevD)
#### Post date: [May 15, 2011, 3:03am UTC](https://community.mp3tag.de/t/title-case/12010/10 "2011-05-15T03:03:39Z")
</div>
> ... Must be at least 70 options, but not TITLE! ...
Try to reset the list of tag-fields.
DD.20110515.0709.CEST
#### Post date: [May 15, 2011, 10:10am UTC](https://community.mp3tag.de/t/title-case/12010/11 "2011-05-15T10:10:45Z")
</div>
> [@DetlevD](#):
I don't know how to do that I'm afraid. Could you explain if you get the chance?
#### Post date: [May 15, 2011, 10:30am UTC](https://community.mp3tag.de/t/title-case/12010/12 "2011-05-15T10:30:15Z")
</div>
see
[where is the "title" tag ?](https://community.mp3tag.de/t/11316/1)
#### Post date: [May 15, 2011, 10:46am UTC](https://community.mp3tag.de/t/title-case/12010/13 "2011-05-15T10:46:49Z")
</div>
FANTASTIC. Thanks very much!
### Author: ![anon57082283](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/a/c2a13f/32.png) [@anon57082283](https://community.mp3tag.de/u/anon57082283)
#### Post date: [July 12, 2011, 4:14pm UTC](https://community.mp3tag.de/t/title-case/12010/14 "2011-07-12T16:14:05Z")
</div>
> [@ohrenkino](#):
I'm sorry I'm being thick, is this in custom actions? if so which one?
#### Post date: [July 12, 2011, 5:01pm UTC](https://community.mp3tag.de/t/title-case/12010/15 "2011-07-12T17:01:43Z")
</div>
> [@anon57082283](#):
See [/t/967/1](https://community.mp3tag.de/t/967/1)
to create a new action. If you have come so far that you have entered a name four action(s) then you can select the action type from a dropdown list. There you find an entry for case conversion. Select that and follow the dialogue.
Also enter the characters which indicate the start of a word (and after which the case should change) in the input box at the bottom of the dialogue.
