# Track Length TAG
**URL:** <https://community.mp3tag.de/t/track-length-tag/18501>\
**Category:** Support\
**Created:** [December 9, 2016, 1:02pm UTC](https://community.mp3tag.de/t/track-length-tag/18501 "2016-12-09T13:02:37Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![JerryTag](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/j/c89c15/32.png) [@JerryTag](https://community.mp3tag.de/u/JerryTag)\
**Post date:** [December 9, 2016, 1:02pm UTC](https://community.mp3tag.de/t/track-length-tag/18501/1 "2016-12-09T13:02:37Z")
</div>
Hi
I have searched the forum but have not found an answer.
When I have a number of tracks displayed in MP3TAG, I have a column for the track's length in hh:mm:ss format.
I wish to store that length in the appropriate ID3 TAG. There are a number of %length% fields in MP3TAG but, I have tried all sorts of manipulations and cannot get the track length to store in a tag. I am sure I am missing something. How does one store the track length in a TAG?
Jerry B
**Post date:** [December 9, 2016, 1:59pm UTC](https://community.mp3tag.de/t/track-length-tag/18501/2 "2016-12-09T13:59:52Z")
</div>
Hi
Please ignore my previous post about adding track time to the track Tag list. I finally found the function that allows me to do that.
For those wanting to do the same thing, or something similar, use MP3TAG Function TAG - TAG.
The following is for storing the track length.
In the displayed dialog box:
Field: Length
Format: %\_length%
I tried other fields but the audio track I used as a test track did not have any other information.
Jerry B
**Author:** ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)\
**Post date:** [December 9, 2016, 4:30pm UTC](https://community.mp3tag.de/t/track-length-tag/18501/3 "2016-12-09T16:30:48Z")
</div>
As the length is already part of the header (and cannot be modified by MP3tag) I wonder what purpose a duplication of that information should serve.
The proper fieldname is %\_length%
**Post date:** [December 10, 2016, 5:46pm UTC](https://community.mp3tag.de/t/track-length-tag/18501/4 "2016-12-10T17:46:03Z")
</div>
I am writing a [VB.NET](http://VB.NET) application where I am using a ID3V2 library that doesn't return header information. All information is accessed by TAGs. I could modify the source code to return the header information, but decided to use the library DLL as is. Note that I am not **_modifying_** the length but just want the TAG, TLEN, to be in the file. If you have a better way, please advise.
Jerry B
**Author:** ![system](https://community.mp3tag.de/uploads/default/original/2X/c/ce7035d426cb755a7916793326d23b465222a407.png) [@system](https://community.mp3tag.de/u/system)\
**Post date:** [February 9, 2026, 12:26pm UTC](https://community.mp3tag.de/t/track-length-tag/18501/5 "2026-02-09T12:26:33Z")
</div>
