# Use "replace with regular expression" on many albums at once
**URL:** https://community.mp3tag.de/t/use-replace-with-regular-expression-on-many-albums-at-once/16531
**Category:** General Discussion
**Created:** [January 21, 2015, 6:54pm UTC](https://community.mp3tag.de/t/use-replace-with-regular-expression-on-many-albums-at-once/16531 "2015-01-21T18:54:30Z")
**Posts on this page:** 3
**Page:** 1
<div class="post-metadata">
### Author: ![AMJF](https://community.mp3tag.de/letter_avatar_proxy/v4/letter/a/3e96dc/32.png) [@AMJF](https://community.mp3tag.de/u/AMJF)
#### Post date: [January 21, 2015, 6:54pm UTC](https://community.mp3tag.de/t/use-replace-with-regular-expression-on-many-albums-at-once/16531/1 "2015-01-21T18:54:30Z")
</div>
I have several series of albums with names like these:
demos - pc (a)
demos - pc (g)
And which in this case runs in an alphabetical sequence from a to g, otherwise identical.
What I'd like to do is to add a prefix string to the album names, but don't want to have to do it for each one. I thought of using a "Replace with regular expression" with this:
^demos - pc (.)$
But how do I format the replacement string so that the letter in brackets (the ".") is preserved? As far as I can tell, the replacement string is a literal string.
### Author: ![ohrenkino](https://community.mp3tag.de/user_avatar/community.mp3tag.de/ohrenkino/32/4843_2.png) [@ohrenkino](https://community.mp3tag.de/u/ohrenkino)
#### Post date: [January 21, 2015, 7:08pm UTC](https://community.mp3tag.de/t/use-replace-with-regular-expression-on-many-albums-at-once/16531/2 "2015-01-21T19:08:38Z")
</div>
> [@AMJF](#):
> demos - pc (a)
> demos - pc (g)
> ... "Replace with regular expression" with this:
> ^demos - pc (.)$
I can hardly see a difference ...
if you want to keep the "." in brackets but it is variable then a construction like
search: ((.))
Replace: ($1)
would work...
### Author: ![DetlevD](https://community.mp3tag.de/user_avatar/community.mp3tag.de/detlevd/32/123_2.png) [@DetlevD](https://community.mp3tag.de/u/DetlevD)
#### Post date: [January 21, 2015, 8:26pm UTC](https://community.mp3tag.de/t/use-replace-with-regular-expression-on-many-albums-at-once/16531/3 "2015-01-21T20:26:39Z")
</div>
> [@AMJF](#):
> demos - pc (a) ... demos - pc (g)
> What I'd like to do is to add a prefix string to the album names, but don't want to have to do it for each one. ...
This should work ...
**Action .....: Format value Field ......: ALBUM Formatstring: 'prefix string '%ALBUM%**
DD.20150121.2226.CET
