Hello,
this is an awesome script, with the new beatport api this is the best solution i know to keep tags.
But one question.. How do you remove tags like 'BP SINGLE TRACK #', '(OM)' .. ?
Thank you in advance !
Hello,
Thanks. FYI it uses the plain old html pages instead.
For your (OM) fix see inside the script:
replace " (Original Mix)" " (OM)" # Replace " (OM)" to your liking, block this with # to keep original setting
And in the track scripts remove all this code OR place a '#' in front of each line like so:
# ALBUM [BP SINGLE TRACK #]
# outputto "ALBUM"
# say " [BP SINGLE TRACK #"
# sayoutput "BEATPORT_TRACK_ID"
# say "]"
PS: Read the readme file that came with the scripts. It will give you a better understanding of how they work.
First off...
This script is incredible.
As someone that has been using MediaMonkey for years and has successfully cleaned up all of my music collection using it, I thought I had everything I needed.
Then I tried to clean up the DJ music. The OCD part of me wanted/needed the album art and a lot of my music was lacking it.
I looked high and low and everything I tried cleaned things up provided I had the album name. Unfortunately, with DJ music, I typically only had the artist, track and remix name. As a result, a lot of the search engines failed me.
So... now that I have thanked you, I'm wondering if there is one more option I'm looking for.
Currently (unless I'm missing it), I have to search each track. One by one.
I'm wondering if this script has the ability to go through all of my music and then present me with the ability to verify each track consecutively. I don't know if MP3Tag allows it.
Any suggestions on how to accomplish this?
In short:
I'd like to highlight all of my music. Run the script.
Then verify each one before accepting changes.
Thanks again for your work-
No problem.
To answer your question mp3tag cannot do what you want or scripts because they can only parse one page at a time. It's would make life that little bit easier but not critical IMO.
Hope this helps.
Thanks for the suggestion. I'll give it a go.
Cheers-
# outputto "ALBUM"
# say "]"
Save the .src file to make the changes take effect in mp3tag or restart mp3tag. Can you attach the .scr so I can see the problem you're having. Why are you deleting .src files?
I have restarted and saved the file. I have deleted files to see if something change in Mp3tag but no. I have reinstalled Mp3tag and now when I put files in sources directory I have nothing in Mp3tag scripts.
Beatport_by__stevehero_v4.0_SINGLE_TRACK_Search_by__Album_Artist___Title.src (18.2 KB)
Right click on the mp3tag icon on your desktop. Clock properties. Then click open folder location. In there should be the folder where your scripts are held under data>sources. Or re-read the part in post #1 about installation of scripts. This should take you to the location. Your script looks fine. Not at my computer right now so can't test it.
This post by Dano fully covers it. freedb and Web Sources
You will find the currently active .src files in the folder ...
%appdata%\Mp3tag\data\sources
respectively
%appdata%\Roaming\Mp3tag\data\sources
Read there ...
DD.20140214.0945.CET
Nice, thank you all !
Hi. How can i tag without (Company) from "Label (Company)" ?
For example http://www.beatport.com/label/armind-armada/40
Edit:
Found a method to do it with mp3-tag's built in actions.
Grabbing everything after/including the space before the first bracket. Remember to add a space before the regex.
Field: PUBLISHER
Regular expression: \s(.+?)"
Replace with: leave this blank
Best do it inside the release scripts, change:
# PUBLISHER/LABEL
outputto "PUBLISHER"
findinline "label\":{" 1 1
sayregexp "(?<=name\":\")[^\"]+"
To:
# PUBLISHER/LABEL
sayregexp "(?<=name\":\").+?(?=\"|\s+\()"
Tested on: http://www.beatport.com/release/man-hands/1241966
Single Track scripts:
# PUBLISHER/LABEL
gotochar 1
findinline "\"label\":{" 1 1
sayregexp "(?<=\"name\":\")[^\"]+" "" "\"images\""
To:
# PUBLISHER/LABEL
gotochar 1
sayregexp "(?<=name\":\").+?(?=\"|\s+\()" "" "\"images\""
Didn't test on Single track scripts but it should be okay.
Just to thank you so much for your script. It has helped me dramaticaly. All the best for your awesome work and thank you again.
Why, thank you and welcome to the forum.
How can i remove a tags '_time chek' & 'comment' from v4.0 RELEASE Search by Release
for example http://www.beatport.com/release/overcome/1248310
It's looks like you've modified the script because in my test of that URL. It appears like:
To remove fields read the readme file that came with the scripts.
This is definetely a big help to all those zippyshare DJs.. Just kidding (not kidding), nice job writing the script, but seriously who needs to buy from beatport anymore thesedays when you can get both music and tags without it?
I was wandering if it was possible to edit the script so it deleted all the file's original tags before writing the new beatport tags? I only ask because I often find myself deleting some fields and think it'd be much easier if I could incorporate it into the script but I'm too stupid to figure it out.
Thanks for taking the time to write the script btw. It's much appreciated.
Hi, thanks and sorry for the late reply. I'm afraid this cannot be done. My only advise is to write all the tags that the script rips from beatport which is quite a few and that way it will overwrite as many as possible. Then create and an action like this which I use or similar to suit your needs.
Name of action group: Clean-Up 1.1 # Remove Unwanted Tags
Action type: Remove fields except
Fields to leave (semicolon-separated): RELEASETIME;ALBUM;ALBUM ARTIST;ALBUMARTIST;ARTIST;BPM;COMMENT;DATE;DISCNUMBER;ENCODEDBY;GENRE;INITIALKEY
;PUBLISHER;TITLE;TRACK;YEAR;PICTURE;COMPILATION;CATALOG #;ISRC;COUNTRY;DISCOGS_MEDIATYPE;DISCOGS_RELEASE_ID;WWW;UNSYNCEDLYRICS;MIXARTIST
;TOTALTRACKSRELEASETIME;ALBUM;ALBUM ARTIST;ALBUMARTIST;ARTIST;BPM;COMMENT;DATE;DISCNUMBER;ENCODEDBY;GENRE;INITIALKEY
;PUBLISHER;TITLE;TRACK;YEAR;PICTURE;COMPILATION;CATALOG #;COUNTRY;DISCOGS_MEDIATYPE;DISCOGS_RELEASE_ID;WWW;UNSYNCEDLYRICS;MIXARTIST;TOTA
LTRACKS;STYLE;MEDIATYPE;REMIXER;TIME;PODCAST;TOTALDISKS;BEATPORT_LABEL_URL;BEATP
O
RT_TRACK_ID;BEATPORT_TRACK_URL;BEATPORT_RELEASE_ID;BEATPORT_ARTIST_URL;BEATPORT_
I
TEM_TYPE;SOUNDCLOUD_TAGS;ENERGYLEVEL
