Apparently, they changed their URL, I try to modify the script with the new URL, but it was in vain, as it did not connect with the server Beatport.
Sorry for my bad English.
Greetings.
Please fix script for new url "pro.beatport.com".
yes! please fix..the new beatport URL delete all the data
Little tip bro :slight_smile:
and you got old beatport, links work on mp3tag.
...and whats the tip? I don't get it, I attempted to put the pro url in the script by chance & it still doesn't connect.
I think its not possible to get info from the website. I tried a little last night but https as opposed to http ones are more secure as to who accesses them.
Maybe someone else can shed some light on this?
No comments in months to say thanks and all I see is a sea of pleases.. Begging is not attractive :wink:
Hello all together :wink:
Just a few days ago I found this script to edit all my MP3s completely with the right Tags (no panic, all MP3s are legal bought at different Stores). After I tried out this script, I have to say: It's great!
Unfortunately Beatport just changed his address to pro.beatport.com and so the script does not work.
But with a little bit experience I found a way to make this script workable, only with some changes in the src-file. It's easy...
Tipp removed, because it wasn' stable.
Please look at startup, where you can find the new update by stevehero.
Nice!!! It work for me! thanks!
I was unaware of the classic BP link at the bottom. I will google to see if this will be a updated or kept online.
I'm bundling the scripts now with the working classic BP link and they should be up shortly. With some bug fixes from the v4.0 release which will be documented in the Beatport by &stevehero v4.0#Version History + Readme (View In Notepad ++).src file
THANK YOU for noticing this Komaro.
Lets hope BP don't keep that poxy new site :wink:
Have you tried tagging old songs from the script using the URL method? It doesn't work. Can you remove this post please. As it's just a quick fix and not a proper one. Other things were broken since the 4.0 release such as:
# v4.1
FIX         BP Classic update: Various scripts that use the URL parsing method
FIX         BP Classic update: Camelot Key conversion wasn't working with the new beatport classic URL
ADDED       2 scripts with both Genre + Comment Tag not parsed from beatport, handy when retagging mp3's
FIX         Various other bugs: & to & | (( & )) to ( & )
FIX         Bug when COMPILATION was set
FIX         ALBUMARTIST field when they contain '-' (http://www.beatport.com/release/defjam/359225)
FIX         Small bug in index search UI when Remixer appeared 'Cedric Gervais ● x' is now just 'Cedric Gervais'
FIX         Small bug in index single track search when a "quote" appeared in the release
FIX         "(Origninal)" to "(OM)" bug fix when it appeared in a release
Classic BP Update in starting post.
stevehero, for my part I thank you for having created this spectacular script. I tried modifying components of the script with the new URL, but it was all in vain. If you need help with the update, I offer to help you do this.
Greetings and sorry for my bad English.
Thanks for updating and this wonderful script!
Check starting post for the working update. V4.1. And thanks for the support ^^^^^^
No, I just couldn't try this. I tried only the Release search by Artist + Release, Artist + Title and the Single Track search by artist + Title - and they all worked properly.
I edited my post...
Thank you for your fast update :slight_smile:
EDIT: Maybe a little bug? I'm searching for the Tags of the following Track: Tilthammer - Last Hero (Original Mix). If I use the Single Track Search by Artist & Title, it shows me the right track included the name of the release (Animasola EP 3). If I use the Release Search by Artist & Title it doesn't show me the right track!?
No, not a bug. The release searches are solely for tagging releases. i.e more than one track on a release and use the release search function of BP. Some releases have single tracks but the majority don't.
If you want track tags where there is more than one track on the release then use the SINGLE TRACK scripts and not the RELEASE ones. All this is explained in the starting post.
Thank you for the explanation. I read the starting post, but I think, I misunderstood something. Now it's clear :wink:
Maybe I mentioned it in the thread here somewhere. It's got plenty of posts so I might make it clearer in the 1st post. The two links at the top of the first post give examples of release pages and track pages.
Starting post now updated to make it clear how to use the track and release scripts.
Hi Everybody!
Just few words to THANK YOU for all your job on this script, and for your reactivity.
I'm using this script a lot because it makes me save a lot of time.
I was a little worried some days ago when Beatport went to Beatport Pro.
Thank you again for all your hard work!
See You.
:music:
very nice script. I'd like to have artist and mixartist in the field for ARTIST and seperated by a comma. How can I code this? Can someone help me?
The Problem is, if there is no mixartist there should be no comma. I need a code snipped with an "if..." I think but dunno how to code this.
Greez, skrippi :slight_smile:
