@stevehero hello mate, I'm getting the same issue while trying to tag using the old classic.beatport.com URL . Any chance to use directly the beatport.com URL?
Thank you for te support.
Gregory
Gregory
beatport classic search is broken at present
Look for yourself.
http://classic.beatport.com/search?query=this+is+not+working
I'm not rewriting the script for something that will be fixed before I have them wrote.
I hate to sound like a broken record but mine pulls all the same info. Even the genre now matches that of the bp new site.
Looks like it's still broken.. Just when I was about to do a large number of files
Looks like they're rebuilding the index or st. like this...
http://classic.beatport.com/search?query=Booka+Shade - doesn't work
http://classic.beatport.com/search?query=Mount+Kimbie - works
So it was. something works, something does not work
I'm sure they cannot fix all broken searches at once and will take time for all to be back to normal. At least they are not leaving it like it was.
but it is possible to do a search through the primary address (beatport.com). it seems that they do not do anything (the next answer with support, like the last one)
It is, but It's been only a week. Like they said, they are working on it.
Actually a week is 7 days.
Were almost at two weeks now
Wouldn't it be the other way around since the new website came later? All searches work on the new version of Beatport. I hate it not being able to code something like this: I would've disregarded your stupid warning
and changed it myself. The only thing I actually understand is that the code looks for HTML elements on the website and does things with that. Anyway: I get why you choose to use the classic instead of the new website for this script.
So what is the solution for this situation?
How can make it work again this script?
Wait for beatport to fix the database or wait for @stevehero to change the code so it uses www.beatport.com instead of classic.beatport.com. But the latter one isn't gonna happen I guess.
Wow, so many samey comments.
Guys stop flooding this thread with the same thing. I also know what different urls beatport use. I don't have to be linked to them in every post.
Let them fix it.
--------- This is not the end of the world ---------
Hello,
If your search is not working (error 500) try to do the same search but a little bit different.
Let me explain it with examples:
"navar ava mea" : not working : http://classic.beatport.com/search?query=navar+ava+mea
"navar mea" : working :http://classic.beatport.com/search?query=navar+mea
"cubicolor falling" : not working
"cubicolor falling original" : working
If you try to add / remove some words in your search you can find one which works. It's annoying but i tagged a lot of "error 500" files using this "trick".
Hope it will help.
Already noticed and this is I'm worry about. Beatport has nothing to fix on their URL since they only adjust their code for smarter search results in their shop.
I hope someone build a new script to tag directly from beatport.
Thank you,
Veggera
Finally!! It seems that the problem with the search is fixed.
Guys. WHAT. DID. I. TELL. YOU.
I'd be pulling my hair out if I spent a week or more rewriting the same scripts. I have better things to be doing.
Glad it's fixed now. People need more patience.
changed format INITIALKEY
This bug could of existed as I don't use that tag.
I'll post a new batch of scripts later on for this.
Thanks for catching it.
Under the line (dont delete this)
replace "♯" "#" # Fix
ADD this in each script write:
replace "♭" "♭" # Fix
UPDATE, ver 4.4
" As always, read the readme before overwriting your src files. "
