Need more info. What version of my script, what script, url of release you want to parse?
Figured it out, my bad. The problem was that I only unpacked several .src scripts and no .irc or .md files. Didn't realize those were necessary!
do you have any idea why Beatport in most cases do not find the release when the Artist and Album name is filled. When I delete the Album artist, than the release will be found.
1 2 3 ![4|690x370]
and that's the 4th picture
Works here with the latest scripts. Try updating them.
Hi stevehero,
thank you for your work!
in version 4, there was a possibility to edit scripts to get (Original Mix) in the title. How can I modify the version 5 to get the title in that way?
Thanks
Change all the .inc files where it says:
replace " (Original Mix)" ""
To:
#replace " (Original Mix)" ""
Pretty sure that this has already been asked and answered here, but I can't find the relevant post - where can I configure Mp3tag/your script to NOT remove anything from the album artist & the release search fields?
The .inc files are where this happens. Not sure why you want "the" included. I found that sometimes it causes more search results.
The "the" was only an example, sometimes I get really weird results - here's one example:
Changing "That's The Way EP" to "Thats Way" is really bad, I think you would agree to that :wink:
I already checked the inc file (I'm using "Beatport by &stevehero v5.0_Release Search.inc"), but could not find the related part...
When putting code into the forum, it's not bbcode. It's markdown so you need to use ``` to wrap the text.
EP is the same as the. It leads to too many results in some situations. Sorry it's the scr files that need changing and not the inc ones.
I might change it so that "the" only gets removed from the start and not mid search string. But so far it has never caused any undesirable search results. In fact it narrows them down more often than not.
Many thanks Steve, your the real "HERO"
Your new version saved my days.
Deepest respect.
Hello, I want to use this plugin but im a Mac user and I don't know where to paste the plugin, anyone can help me?
thanks in advance
Hi and welcome!
It's not possible to use custom Tag Sources with the Mac version — see here for a similar post and further discussion:
Can I use Beatport.com WSS by stevehero with the mac?
No TITLE field. Problem with beatport API?
There's no API, just HTML parsing. What's the URL of the release you're trying to get?
this happens on all tracks. Everything has worked well until today.
I use 5.0 version and mp3tag 3.03.
Check the first post, your version of mp3tag and the scripts need updating.
Everything worked. as I said, the problem was on the beatport side.
