That should work if you delete what I have in them two sections.
You cannot hide the columns and write the tags. It's one or the other unfortunatly.
Just noticed Beatport seem to have gone back and upres'd older artwork.
This release is from 2005 and the artwork is near perfect @1400x1400px.
Removing the text in those 2 'sections', breaks the scripts completely and it does not work for me anymore.
OK. I understand.
Your suggestion works (ie. for 'removing tags' for TRACK ID & URLs )
No, it doesn't. I knew it would work.
Please see.
# Original IndexFormat
# New IndexFormat
And:
# THESE ARE THE ITEMS THAT ARE COMMENTED OUT BELOW
# THESE ARE THE ITEMS THAT ARE COMMENTED OUT ABOVE
Here's an example of the Beatport by &stevehero v5.0_Release Search.inc
#    _                   _                        _
#   | |__    ___   __ _ | |_  _ __    ___   _ __ | |_     ___  ___   _ __ ___
#   | '_ \  / _ \ / _` || __|| '_ \  / _ \ | '__|| __|   / __|/ _ \ | '_ ` _ \
#   | |_) ||  __/| (_| || |_ | |_) || (_) || |   | |_  _| (__| (_) || | | | | |
#   |_.__/  \___| \__,_| \__|| .__/  \___/ |_|    \__|(_)\___|\___/ |_| |_| |_| _
#                    (_)     | | |   | |                 | |                   | |
#    ___   ___  _ __  _  _ __|_| |_  | |__   _   _   ___ | |_  ___ __   __ ___ | |__    ___  _ __  ___ TM
#   / __| / __|| '__|| || '_ \ | __| | '_ \ | | | | / __|| __|/ _ \\ \ / // _ \| '_ \  / _ \| '__|/ _ \
#   \__ \| (__ | |   | || |_) || |_  | |_) || |_| | \__ \| |_|  __/ \ V /|  __/| | | ||  __/| |  | (_) |
#   |___/ \___||_|   |_|| .__/  \__| |_.__/  \__, | |___/ \__|\___|  \_/  \___||_| |_| \___||_|   \___/
#                       | |                   __/ |
#                       |_|                  |___/
#                                 .:: [v5.11 by stevehero™] [2021.05.07] ::.                              #
# https://community.mp3tag.de/t/beatport-com-wss-by-stevehero-release-single-track-artwork-tagging/12568  #
#                          .:: Please read the 'Version History + Readme' file ::.                        #
#                    .:: DO NOT COPY/MODIFY OR REDISTRIBUTE THIS WITHOUT PERMISSION ::.                   #
#                 .:: This file should be stored in your tag sources sources directory ::.                #
#                                      %APPDATA%\Mp3tag\data\sources                                      #
#                                  and requires Mp3tag v3.03d or above.                                   #
#                          .:: You can buy me a beer or an EP on beatport ::.                             #
#     https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=EZVJN8ZLEU8KC&source=url       #
# TO DO: (WSF Help: https://docs.mp3tag.de/tag-sources)
# 1. Leading zero user option on track no.
# 2. TRACK/TOTALTRACKS to fix. e.g. 1/10, 2/10, 3/10 etc.
# 3. Once the json_select_many "artists" "name" " ● " "5" thing has been implemented. Change back to the Original IndexFormat and add that.
[Name]=beatport.com [v5.11 by stevehero™] (◣_◢)
[BasedOn]=https://www.beatport.com
[IndexUrl]=https://www.beatport.com/search/releases?q=
[AlbumUrl]=
[WordSeparator]=+
# [IndexFormat]=% ↓ TYPE%|% ↓ EXCLUSIVE%|% ↓ ID (◣_◢)™%|% ↓ PRICE%|% ↓ RECORD LABEL%|% ↓ RELEASED%|% ↓ CATALOG%|% ↓ RELEASE%|% ↓ ARTIST/S%|% ↓ REMIXER/S%|% ↓ GENRE/S%|%_URL%
# New IndexFormat
[IndexFormat]=% ↓ TYPE%|% ↓ RECORD LABEL%|% ↓ RELEASED%|% ↓ CATALOG%|% ↓ RELEASE%|% ↓ ARTIST/S%|% ↓ REMIXER/S%|% ↓ GENRE/S%|%_URL%
[Encoding]=url-utf-8
[ParserScriptIndex]=...
debug "on"  "W:\Apps (Portable)\Music Apps\Mp3tag\data\sources\BEATPORT debug index.html" 20 # Place before headings to want to debug
# debug "off" "W:\Apps (Portable)\Music Apps\Mp3tag\data\sources\BEATPORT debug index.html"    # Place after headings to want to debug (OPTIONAL)
findline "<!DOCTYPE html>"
findinline "<!DOCTYPE html>"
joinuntil "</html>"
replace "|" "$verticalBar()"
regexpreplace "(?i).*?window\.Playables\s*?=\s*?(\{.+);.*?window\.Sliders\s+=\s+\[.*" "$1"
regexpreplace "(\"exclusive\":\s+)(true\,)" "$1 "✓","
regexpreplace "(\"exclusive\":\s+)(false\,)" "$1 "╳","
regexpreplace "(\"type\":\s*\")([^\"]+)" "$1\u$2" # Upper case first letter for release type
regexpreplace "(\"artists\":\s+\[(?:{\"id\"[^\}]+\},\s){1,2}{\"id\"[^\}]+\},\s).+?(\])" "$1{\"id\": 0, \"name\": \" + others...\", \"slug\": \"no-mas\"}$2" # Limits the result of this array length to 3.
regexpreplace "(\"remixers\":\s+\[(?:{\"id\"[^\}]+\},\s){1,2}{\"id\"[^\}]+\},\s).+?(\])" "$1{\"id\": 0, \"name\": \" + others...\", \"slug\": \"no-mas\"}$2" # Limits the result of this array length to 3.
regexpreplace "(\"genres\":\s+\[(?:{\"id\"[^\}]+\},\s){1,2}{\"id\"[^\}]+\},\s).+?(\])" "$1{\"id\": 0, \"name\": \" + others...\", \"slug\": \"no-mas\"}$2" # Limits the result of this array length to 3.
json "ON" "current"
json_foreach "releases"
json_select "type" # TYPE
sayrest
say "|"
# json_select "exclusive" # EXCLUSIVE
# sayrest
# say "|"
# json_select "id" # ID
# sayrest
# say "|"
# json_select_object "price" # PRICE
# json_select "display"
# sayrest
# json_unselect_object
# say "|"
json_select_object "label" # LABEL
json_select "name"
sayrest
say "|"
json_select_object "date" # RELEASED
json_select "released"
sayrest
say "|"
json_select "catalog" # CATALOG
sayrest
say "|"
json_select "name" # RELEASES
sayrest
say "|"
# json_foreach "artists" # ARTIST COUNT
# sayrest
# json_foreach_end
# say "|"
json_select_many "artists" "name" " ● " # ARTIST/S
sayrest
say "|"
# json_foreach "remixers" # REMIXERS COUNT
# ifnot "0"
# sayrest
# else
# say "-"
# endif
# json_foreach_end
# say "|"
json_select_many "remixers" "name" " ● " # REMIXERS/S
ifnot ""
sayrest
else
say "-"
endif
say "|"
json_select_many "genres" "name" " ● " # GENRES/S
sayrest
say "|"
say "https://www.beatport.com/release/" # _URL
json_select "slug"
sayrest
json_select "id"
say "/"
sayrest
saynewline
json_foreach_end
[ParserScriptAlbum]=...
# debug "on"  "W:\Apps (Portable)\Music Apps\Mp3tag\data\sources\BEATPORT debug album.html" 20 # Place before headings to want to debug
# debug "off" "W:\Apps (Portable)\Music Apps\Mp3tag\data\sources\BEATPORT debug album.html"    # Place after headings to want to debug (OPTIONAL)
#                                   .:: P A R S I N G   S E T U P ::.                                     #
gotoline 5
joinuntil "</html>"
regexpreplace "(\"description\":\s*\")(\s*\")" "$1No description.$2"                         # Upper case first letter for release type
regexpreplace "\"tracks\": ?\[\s*\]\," ""                                                    # Remove empty track array, IMPORTANT, DO NOT REMOVE!
regexpreplace "(\"id\": (\d+), )(\"name\": \"[^\"]+\", )(\"slug\": \"([^\"]+)\")" "\"artist_url_stevehero_custom\": \"https://www.beatport.com/artist/$5/$2\", $1$3$4" # Fix #2 for BEATPORT_ARTIST_URL to add a new element for the url, IMPORTANT, DO NOT REMOVE!
regexpreplace "(\"released\": )(\"\d+-\d+-\d+\")" "$1$2, \"releaseddate\": $2"               # Create a new item to be parsed for the date field.
# TAG FIXES + OPTIONS
# Old regexs brought over from classic beatport. To add should www.beatport.com have the same issues.
# regexpreplace "(,\"key\":)null,\"" "$1\"shortName\":\"╳\"},\""                               # Missing key
# regexpreplace "(?i)(\",\"title\":\".+?)(\s\[Bonus Track\])(.{1,75})(\",\"slug)" "$1$3$2$4"   # Title [Bonus Track] feat. artist (Remixer) => Title feat. artist (Remixer) [Bonus Track]
# regexpreplace "(?i)\(([^\"]{1,40})\s(feat[^\"]{1,40})Remix\s*\)" "$2($1)"                    # Title (artist Remix feat. Remixer Remix) => Title feat. artist (Remixer)
# regexpreplace ",\"name(\":\"[^\"]+\",\"slug.{1,50}artist\")" ",\"artistName$1"               # Artist/s
# regexpreplace ",\"name(\":\"[^\"]+\",\"slug.{1,50}remixer\")" ",\"remixerName$1"             # Remixer/s
# replace ",\"bpm\":0," ",\"bpm\":╳,"                                                          # Zero BPM fix
regexpreplace "(?i) \bep\b" " EP"                                                            # Fix Ep to EP
regexpreplace "(?i) Feat\. " " feat. "                                                       # Fix to lower case
regexpreplace "(?i)(\(|\[)(feat\.\s.+?)(\]|\))" "$2"                                         # Title (feat. artist) => Title feat. artist
regexpreplace "(?i)(\s*(Remix|Rework)\)\s*)\(Remix\)\s*" "$1"                                # Title (Rework) Remix & Title (Remix) Remix
regexpreplace "(?i)(\w)(\(|\[)feat\.\s+(.+?)(\]|\))" "$1 feat. $3"                           # Title(Feat. artist) => Title feat. artist
regexpreplace "(?i)(feat\.\s+[^\"]{1,40})\s+feat\." "$1,"                                    # Title feat. artist feat. artist' => 'Title feat. artist, artist
regexpreplace "(?i)\s+f(ea)?t\.*\s+" " feat. "                                               # 'ft. => feat.' 'Ft. => feat.' 'Feat. => feat.'
regexpreplace "\(+" "("
regexpreplace "\)+" ")"
regexpreplace "(?i)(\"mix\":) \"\s*\(Original Mix\)\s*\(Original Mix\)\s*\"" "$1 \"Original Mix\""  # Fix double '(Original Mix)'.
regexpreplace "(?i)(\"mix\":) \"\s*\(Original\)\s*\s*\"" "$1 \"Original Mix\""                      # Fix '(Original)'.
regexpreplace "(?i)(\"mix\":) \"\(([^\"]+?)\)\"" "$1 \"$2\""                                        # Fixed the extra ( and ) in the mix json
replace "\"Original Mix\"" "\"\""        # Replace "" to your liking, block this with # to keep the original setting
replace " feat. " " feat. "        # Here you can change the way you want 'feat.' formatted
replace " Remix) (Original Mix)" " Remix)"                                                          # Fix ' Remix (Original Mix)'
replace "\"type\":\"track\"" "\"type\":\"Track\""                                                   # Capital letter
replace "\/" "/"        # URL fixes
# TRACK OPTIONS
# regexpreplace "(txt-grey\">\s*)(\d)( <)" "$1 0$2$3"                                      # Add leading zeros to TRACK
# INITIALKEY TO CAMELOT NOTATION
# Please DO NOT change values
# You can delete all these replace lines below to get 'Dmin' etc.
replace "\u266d" "♭"             # Fix
replace "\u266f" "#"             # Fix
replace "\"G# min\"" "\"01A\""
replace "\"A♭ min\"" "\"01A\""   # SAME KEY #
replace "\"D# min\"" "\"02A\""
replace "\"E♭ min\"" "\"02A\""   # SAME KEY #
replace "\"A# min\"" "\"03A\""
replace "\"B♭ min\"" "\"03A\""   # SAME KEY #
replace "\"F min\"" "\"04A\""
replace "\"C min\"" "\"05A\""
replace "\"G min\"" "\"06A\""
replace "\"D min\"" "\"07A\""
replace "\"A min\"" "\"08A\""
replace "\"E min\"" "\"09A\""
replace "\"B min\"" "\"10A\""
replace "\"F# min\"" "\"11A\""
replace "\"G♭ min\"" "\"11A\""
replace "\"C# min\"" "\"12A\""
replace "\"D♭ min\"" "\"12A\""   # SAME KEY #
replace "\"B maj\"" "\"01B\""
replace "\"F# maj\"" "\"02B\""
replace "\"G♭ maj\"" "\"02B\""   # SAME KEY #
replace "\"C# maj\"" "\"03B\""
replace "\"D♭ maj\"" "\"03B\""   # SAME KEY #
replace "\"G# maj\"" "\"04B\""
replace "\"A♭ maj\"" "\"04B\""   # SAME KEY #
replace "\"D# maj\"" "\"05B\""
replace "\"E♭ maj\"" "\"05B\""   # SAME KEY #
replace "\"A# maj\"" "\"06B\""
replace "\"B♭ maj\"" "\"06B\""   # SAME KEY #
replace "\"F maj\"" "\"07B\""
replace "\"C maj\"" "\"08B\""
replace "\"G maj\"" "\"09B\""
replace "\"D maj\"" "\"10B\""
replace "\"A maj\"" "\"11B\""
replace "\"E maj\"" "\"12B\""
# GENRE
# regexpreplace ",\"genres\":\[.+?name\":\"([^\"]+)[^]]+\]" "trackGenre>>$1>"              # Fix
# regexpreplace "(trackGenre>>)(Dee|Ele|Min|Pro|Tec)(.+?)\s?(House)?.{0}>" "$1$4 $2$3>"    # 'Progressive House' to 'House Progressive'
# replace "trackGenre>>House Progressive>" "trackGenre>>House Prog>"                       # 'Progressive House' to 'House Prog'
#                                      .:: U S E R   O P T I O N S ::.                                    #
# DATE OPTION BELOW (Defaults to YYYY-MM-DD so leave this untouched for this output)
# Only leave one of these line below uncommented with no # preceding the line
regexpreplace "(releaseddate\":\s*\")(\d\d\d\d)-(\d\d)-(\d\d)" "$1$3$4"     # DATE in MMDD format
# regexpreplace "(releaseddate\":\s*\")(\d\d\d\d)-(\d\d)-(\d\d)" "$1$4$3"   # DATE in DDMM format
# YEAR OPTION BELOW (Defaults to YYYY-MM-DD so leave this untouched for this output)
# regexpreplace "(released\":\s*\")(\d\d\d\d)-(\d\d)-(\d\d)" "$1$2-$4-$3"   # YEAR in YYYY-DD-MM format
# regexpreplace "(released\":\s*\")(\d\d\d\d)-(\d\d)-(\d\d)" "$1$4-$3-$2"   # YEAR in DD-MM-YYYY format
# regexpreplace "(released\":\s*\")(\d\d\d\d)-(\d\d)-(\d\d)" "$1$2"         # YEAR in YYYY format
# TOTALTRACKS OPTION BELOW
# regexpreplace "(ec-item track\" data-ec-position=\")(\d)(\")" "$1 0$2$3"    # Add leading zeros to TOTALTRACKS
# TRACK OPTION BELOW
# regexpreplace "(ec-item track\" data-ec-position=\")(\d)(\")" "$1 0$2$3"    # Add leading zeros to TRACK
#                                   .:: H T M L    P A R S I N G ::.                                      #
outputto "_TIME_CHECK"  # shows track length when only single track available, convenient to check time comparison
findinline "<!-- END LOADING OVERLAY -->" 1 1
findinline "<li class=\"bucket-item ec-item track\" data-ec-position=\"" -1 1
findinline "position=" 1 1
if "\"1\""
gotochar 1
findinline "<p class=\"buk-track-length\">" 1 1
sayuntil "<"
endif
outputto "TOTALTRACKS"
gotochar 1
findinline "position=\"" 1 1
sayuntil "\""
outputto "ALBUMARTIST"
gotochar 1
findinline "<ul class=\"interior-release-chart-content-list\">" 1 1
findinline "<span class=\"value\">" 1 1
if "Various Artists"
say "VA"
outputto "COMPILATION"
say "1"
else
say "0"
endif
#                                   .:: J S O N    P A R S I N G ::.                                      #
# This will remove the last of the unwanted html code from being parsed, leave this before the start json parsing code
json "ON" "current"
json_select_array "releases" 1
outputto "ALBUM"
json_select "name"
sayrest
ifnotoutput "ALBUMARTIST"
json_select_many "artists" "name" ", "
sayrest
endif
outputto "BEATPORT_LABEL_URL"
say "https://www.beatport.com/label/"
json_select "slug"
sayrest
json_select "id"
say "/"
sayrest
outputto "BEATPORT_RELEASE_ID"
json_select "id"
sayrest
outputto "CATALOG #"
sayrest
outputto "COVERURL"
json_select_object "images"
json_select_object "large"
json_select "url"
regexpreplace "image_size\/\d+x\d+" "image"
sayrest
outputto "DATE"
json_select "releaseddate"
sayrest
outputto "PUBLISHER"
json_select "name"
sayrest
outputto "YEAR"
sayrest
outputto "UNSYNCEDLYRICS"
say "Release type:\\u0009\\u0009"
json_select "type"
sayrest
say "\\u000d\\u000a----------------------------------------------\\u000d\\u000a"
say "Exclusive to beatport:\\u0009"
sayrest
json_select "description"
sayrest
say "Tagged by:\\u0009\\u0009Mp3Tag w/ beatport.com scripts [v5.11 by stevehero™] (◣_◢) (http://bit.ly/2EmyidV)"
outputto "WWW"
json_select "slug"
sayrest
json_select "id"
say "/"
sayrest
json_unselect_object # Deselect releases array
json_foreach "tracks"
json_select "component"
if "Release Track Listing"
# outputto "TRACKTEMP" # TRACK/TOTALTRACK|TRACKTEMP
# # sayregexp "(?<=txt-grey\"> )[^<]+" "" "<<endTrack>>"
# sayrest
# # The bottom two lines control whether or not you have the TOTALTRACKS appended. e.g. 1/10, 2/10, 3/10 etc.
# # say "/"
# # sayoutput "TOTALTRACKS"
# say "|"
outputto "BEATPORT_ITEM_TYPE"
json_select "type"
sayrest
say "|"
outputto "BEATPORT_ARTIST_URL"
json_select_many "artists" "artist_url_stevehero_custom" "\\u005c\\u005c"
sayrest
say "|"
outputto "TITLE" # TITLE|TITLETEMP
json_select "name"
sayrest
json_select "mix"
ifnot ""
say " ("
sayrest
say ")"
endif
say "|"
outputto "ARTIST"
sayrest
say "|"
outputto "MIXARTIST"
json_select_many "remixers" "name" ", "
sayrest
say "|"
outputto "_LENGTH"
json_select_object "duration"
json_select "minutes"
sayrest
say "|"
outputto "BPM"
json_select "bpm"
sayrest
say "|"
outputto "INITIALKEY"
json_select "key"
sayrest
say "|"
outputto "GENRE"
json_select_many "genres" "name" ", "
sayrest
say "|"
outputto "BEATPORT_TRACK_ID"
json_select "id"
sayrest
say "|"
outputto "BEATPORT_TRACK_URL"
say "https://www.beatport.com/track/"
json_select "slug"
sayrest
say "/"
json_select "id"
sayrest
say "|"
# say "|"
outputto "TRACKS"
say "|"
endif
json_foreach_end
json_unselect_object # Deselect tracks array
# TRACK COUNTER FIX ** DO NOT DELETE
# outputto "TITLE"
# sayoutput "TITLETEMP"
# set "TITLETEMP"
# outputto "TRACK"
# sayoutput "TRACKTEMP"
# set "TRACKTEMP"
#                            .:: T A G    C U S T O M I Z A T I O N ::.                                   #
# • You can add your own web source scripting here                                                        #
# • ONLY disable the ALBUM [CATALOG #] here                                                               #
# • Disable the other fields in the .:: R E M O V E    F I E L D S ::. section below                      #
# • To disable place a "#" in front of each line of code between the headings. e.g.                       #
# ALBUM [CATALOG #]        #
  # outputto "ALBUM"        #
  # say " ["        #
  # sayoutput "CATALOG #"        #
  # say "]"        #
  # COMMENT        #
# ALBUM ARTIST
outputto "ALBUM ARTIST"
sayoutput "ALBUMARTIST"
# ALBUM [CATOLOG #]
outputto "ALBUM"
say " ["
say "]"
# COMMENT
outputto "COMMENT"
sayoutput "INITIALKEY"
# DISCNUMBER
outputto "DISCNUMBER"
say "1"
# MEDIATYPE
outputto "MEDIATYPE"
say "BEATPORT STORE"
# RELEASETIME
outputto "RELEASETIME"
sayoutput "YEAR"
say "T00:00:00Z"
# DISCTOTAL
outputto "DISCTOTAL"
say "1"
# MEDIATYPE_ORIGINAL
outputto "MEDIATYPE_ORIGINAL"
say "WEB"
# STYLE
outputto "STYLE"
say "Electronic"
#                                .:: R E M O V E    F I E L D S ::.                                       #
# • To remove fields from parsing delete the # in front of 'set'                                          #
# • Only use this section to remove fields        #
# set "_LENGTH"
# set "_TIME_CHECK"
# set "ALBUM"
# set "ALBUMARTIST"          # ITUNES USES
# set "ARTIST"
# set "BEATPORT_ARTIST_URL"
# set "BEATPORT_ITEM_TYPE"
# set "BEATPORT_LABEL_URL"
# set "BEATPORT_RELEASE_ID"
# set "BEATPORT_TRACK_ID"
# set "BEATPORT_TRACK_URL"
# set "BPM"
# set "CATALOG #"
# set "COMPILATION"
# set "COVERURL"
# set "DISCNUMBER"           # EXTRA FIELD
# set "DISCTOTAL"            # EXTRA FIELD
# set "GENRE"
# set "MEDIATYPE"            # EXTRA FIELD
# set "MEDIATYPE_ORIGINAL"   # EXTRA FIELD
# set "MIXARTIST"
# set "PUBLISHER"            # RECORD LABEL
# set "STYLE"
# set "TITLE"
# set "TOTALTRACKS"          # EXTRA FIELD
# set "TRACK"                # NO'S OF TRACKS E.G. 01/06 (if set goes back to default 1, 2, 3... etc)
# set "TRACKS"               # REMOVES TRACKs (USEFUL FOR WHEN ONLY REQUIRING COVERART SO NO TRACK NUMBERS APPEAR IN ADJUST TAG INFO DIALOG)
# set "UNSYNCEDLYRICS"       # DESCRIPTION ON BEATPORT
# set "WWW"
# set "YEAR"
# SET BY DEFAULT (My own personal preferences)
set "ALBUM ARTIST"           # EXTRA FIELD, ALBUM ARTIST USED IN VLC, FOOBAR 2000 AND OTHERS PLEASE CHECK YOUR MUSIC PLAYER FIRST
set "COMMENT"                # EXTRA FIELD
set "DATE"
set "INITIALKEY"
set "RELEASETIME"
#                                       .:: T H E E    E N D ::.                                          #
#    _                   _                        _
#                       | |                   __/ |
#                       |_|                  |___/
Yes, it does work now
:ok_hand:
I know now, why my previous "attempts" were not working
:rofl:
When you said 'remove', I was actually deleting those 2 x sections completely !
( I was not applying the "#" character to 'remove / escape' those lines )
When I saw that you were meticulous enough in giving me examples where you had entered the "#" already, but for the examples regarding those 2 x sections, the "#" was 'missing', so I went ahead and just removed several lines of the code.
That's the same thing. Commenting # will be ignord by Mp3tag when running them files.
See: Comment (computer programming) - Wikipedia
All of a sudden the [SearchBy]=RELEASE Search by Album Artist doesn't work anymore - example:
Error: "Sorry, no entries are matching your search criteria."
Tested some other scripts with the same result...
Yes, beatport has changed something. Logo has changed. Will looking into this ASAP.
Awesome, thank you very much again!
UPDATE HISTORY
v5.12 2021.06.08
  • FIX: Beatport had changed their pages slightly. joinuntil "</html>" changed to joinuntil "</footer>"
Excellent, thanks again for your super fast action!
For anyone that has modified their scripts, without downloading the new ones, all you have to do is replace:
joinuntil "</html>"
with:
in all of your scripts.
Thank you Steve, Now I understand whats the hero means :wink:
Thanks stevehero
a couple of days ago, that the search for tags did not work, with the new update it already works.
Hello,
Great script !! Well done and very responsive for updates.
Will it be possible to mass tag in a future version?
Thank you
Thanks. Mass tagging is probably the most asked question on any WSS page.
Single page parsing is only available.
Thank you for your continued support.
Sent a small token of my appreciation. :heart:
Thank you for your support. That's an Irish name if ever I saw one :wink:
I have a CSV file:
$filename(csv,utf-16)Title;Artist;Album;Track;Year;Length;Size;Last Modified;Path;Filename;
$loop(%_filename_ext%)%title%;%artist%;%album%;%track%;%year%;%_length_seconds%;%_file_size%;%_file_mod_date%;%_folderpath%;%_filename_ext%;
$loopend()build on %_date% with %_app% - the universal Tag editor - http://www.mp3tag.de/en/
Who can help me add the following fields, please:
ALBUM, ALBUMARTIST, ARTIST, BPM, CATALOG#, GENRE, LENGHT, MIXARTIST. PUBLISHER, STYLE, TITLE, TRACK, WWW, YEAR.
I would really appreciate anyone who could help me :slight_smile:
Hi @jchm and welcome to the forum.
You need to ask that question here in the help section. This is a thread for the beatport web source script.
