outputto "year"
gotoline 1
findline "<dateReleased>"
regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$1-$2-$3" # YEAR IN YYYY-MM-DD FORMAT
#regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$1-$3-$2" # YEAR IN YYYY-DD-MM FORMAT
#regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$3-$2-$1" # YEAR IN DD-MM-YYYY FORMAT
findinline "<dateReleased>"
sayuntil "</"
Change to
outputto "year"
gotoline 1
regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$1" # YEAR IN YYYY FORMAT
#regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$1-$2-$3" # YEAR IN YYYY-MM-DD FORMAT
sayuntil "</"
Hi! Many thanks for your work! Maybe this is a dumb newbie question ...: I have a large music collection, which defines the tags by type: %artist% - %title% ... Individually script works great! Can I customize the script to process the tracks automatically in batch mode?
Is it possible to set the script to only update a field if it is currently blank in the ID3 tag? The reason is, I'd prefer to keep my own keys where mine differ from those on Beatport.
You could help yourself with a little different workflow:
first create an export to save the data you want to keep,
then update the other data with the beatport script,
then re-import the data you just exported.
This works fine, BUT if there's no mixartist (f.e. "Original Mix") then there is always this comma after the artist.
Can someone help me?!
Greez, skrippi
PS:
For the "Beatport by &stevehero#SINGLE TRACK Direct by BEATPORT_TRACK_ID.src" it works very fine if I only add this to section "costumization starts":
# ARTIST
outputto "artist"
say ", "
sayoutput "Mixartist"
But here is the same problem with the comma, if there's no Mixartist...
EDIT:
Maybe something like this:
sayregexp "(?<=[]|[])[^<]+" ", " ""
Sorry I didn't back to you but with a new job I haven't had the man hours to get working on V3.0 of the script. So That seems to be fixed after this weeks holidays. See attached of what the release script will look like. Added are a few wee extra tags as you can see. As this is a completely rewritten .src it warrants the new v3.0 tag
I will upload it once it is tried and tested and tested some more
I still have to figure out what's the best way to manage the VA (Various Artists) in the ALBUMARTIST field. As beatport generally has a single release with one track but may have up to 4/5 artists working on it. Which means it is not a compilation, more a collaboration and I tend to find myself putting in the correct ALBUMARTIST info more often than not and clearing the COMPILATIONS tag.
And noticed a bug. When you release a lot of tracks before he tag of the track which is higher. Let's say I have the 26th track. And he takes from the 25th.
I don't quite understand your problem. Are you using google translate? I tried that release and everything is working okay. See attached screenshot of track 24 onwards.
All I can suggest is re-download the .zip pack HERE and try again.
It is not a problem with the scripts. Click inside the right hand window and scroll down. You will see the problem then. The two tracks do not line up properly. Then select the track in the right window and move down until they line up.
If you have only one song on the album use the single track scripts. It's what they were designed for.
