Do you know the story of the hare and the tortoise?
Writing tricky websource scripts is a never-ending story, very time consuming.
There are much more better technical concepts available in the world, unfortunately there is no way in Mp3tag to use them.
Try to do better things with your life time.
I'm sorry, but another quick fix:
After yesterday's changes at discogs.com, the fields DISCOGS_MASTER RELEASE ID & DISCOGS_MASTER RELEASE URL have been always empty if you tagged from a normal release page. Now the work again.
If you detect other fields with problems, please tell me. Since I'm not using all the fields which my script provides, I don't detect all of these little mistakes.
Hello, I'm getting this error - Error connecting to Server, Invalid data full line expected - with the discogs pone script. I have updated to 2.49b and the latest script. What have I done wrong? Thanks very much!
Have you read & followed my instructions for installation and update from the starting post?
What does your setting mp3 file show in the artist and title field?
Sorry, another fix:
I found another mistake. The export script for generating cue sheets from discogs was exported to the wrong folder.
You don't have to download this update if you move the file "Discogs Pone Create Cue Sheet.mte" from %appdata%\Mp3tag\data</b> to %appdata%\Mp3tag\export</b> manually.
No, it should say "... updated to v.3.18" in both fileds. (or at least v.3.16 to have a working script)
Have you the downloaded the newest version (3.18) from the starting post of this script?
If not, do so.
Did you move the files from the downloaded zip archive into the correct folder?
The correct folder ist the Mp3Tag profile folder: %appdata%\Mp3tag</b>
(just copy&paste this into windows explorer adress bar)
Put the folders from the downloaded zip file into this folder.
(or more complicated: move the mta files to %appdata%\Mp3tag\data\actions and the mte files to %appdata%\Mp3tag\export)
After that, continue with step 3.b from my instruction at the starting post.
First of all thank you very much for the fast update.
I have a question that maybe you can help me. I usually create tags of
Maxi Vinyls on discogs using "Direct by Discogs ID" source. The "track"
field is set by numbers 1,2,3,etc and i would like to change to A1,A2,B1,etc
I did it before this new update but now i can't, how can i fix it?
DISCOGS~TRACK POSITION AS ON RELEASE PAGE = no
DISCOGS~TRACK_ONLY FOR VINYL & CASSETTES: POSITION AS ON RELEASE PAGE = track
or
DISCOGS~TRACK POSITION AS ON RELEASE PAGE = track
DISCOGS~TRACK_ONLY FOR VINYL & CASSETTES: POSITION AS ON RELEASE PAGE = no
The first setting writes the the letters counting system (or whatever is found at discogs) if the mediatype at discogs is Vinyl, Cassettes, Acetate, Shellac, Microcassette or Lathe Cut. For all other Mediatypes a number counting system is used. Either the standard 1, 2, 3, or another one of the DISCOGS~TRACK fields if you have choosen it (you choose it by setting it to "track" or to whatever tag-field you want to write it.
The second setting writes the counting system from the discogs page to alle releases, no matter if Vinyl or CD.
Have you deleted your old setting file or did the update change the settings?
Normally you should keep your old file and delete the new one. The old one holds your settings. The new one is only for those who install the script for the first time.
The DISCOGS~TRACK... fields are not yes/no option fields. You can set the to "no" if you don't want them. But if you want them, you have to type in the tag-field you want to write store in. Normally that would be "track", but you also choose other fields. You can also use more DISCOGS~TRACK... fields parallel if you set them to different tag-fields.
Another special case are the four DISCOGS~TRACK_ONLY FOR... fields. They are only written for specific mediatypes and they overwrite the chosen tag fields.
I haven't changed anything at the multivalue tag fields. I also use them and they work fine. If you set the TEXT OPTION: MULTI... fields to "YES" (or "yes", case doesn't matter) the script should write mutlivalue tags in the corresponding tag fields.
Note that for correct mulitvalue tags in Mp3tag it is necessary:
One additional saving after running the scritp (press CTRL + S)
The fields with multivalue tags must be displayed in the tag panel
All highlighted files must have the same value. So if you press CTRL+S after tagging more releases, that only works if the all have the same values in the multivalue fields. Otherwise (in most cases) you have to press CTRL+S for every single release.
However, if you ignore one of the three points above you end up with tag fields which have "\\" as plain text instead of a marker for multivalue tags. And you said it worked for you before. So I don't know why you have only "" now. Can you please try the following things:
if you use some of the other TEXT OPTION: MULTI... field, do they work correct?
does another update of the script change anything?
if not, can you please send me your setting file one of the src files you got from it?
