[X] Filter fails to respect results of File | Save tags
With the filter operating, the displayed set fails to update to reflect changes in the match set caused by tag changed resulting from File | Save tags.
I think this is indented behaviour. A user might have filtered the file view by a certain criteria and want to perform multiple changes to the files.
If the files are removed automatically as soon as the filtering criteria isn't matched anymore, the user might have to search the files again to apply further changes.
He'd save the set as a playlist, then disengage the filter.
For the design to deliberately show an invalid filter result just for a rare case where the user might want it is not good, I suggest.
