Hello!
Unfortunately, I have a problem tagging the files. I have tried it so far with several files of different origin. I sometimes get over 100 different tags per song suggested and none of them is the right one. Does anyone know where the problem might be?
Could you help us a little?
Like tell us how you try to get the tag information?
What tag information you got and what you expected?
What were the results for a manual search?
For example, I have a folder on the desktop whose directory I select. It's Mp3 from an audio CD which I copied from someone. It is not a music album but songs that do not belong together. I'm using "freedb" as the tag source and picking "based on files". i also tried "web search". in this example i used the search mechanism for a song I already new the Name. the song is not in the list with the 144 entrys. it is the same with every other song. thank you.
In a jiffy: freedb is not the best choice to search individual titles as the search looks for each word in the search string.
It would be better to use a different source.
