Hi there, since 2.37 keeps me alerting that there's new version out, I switched to 2.38.
I started using new version and immediately found one annoying thing - I used to drag only one file into MP3tag windows causing the program to load the whole directory but since 2.38, the program stopped to do this. I checked options for some new feature or checkbox but I didn't find anything like that. I also tried the newest develepment version, it didn't help too.
So, if it's really bug and not a feature, someone could fix that .
Same here, I downgraded to version 2.36 (2.37 kept nagging with the upgrade message, despite "you'll only see this message once" phrase).
I wish it goes back to the previous functionality!
I am using this program at a daily basis, and will probably use it more to rename files (I am using 1-4a Rename for that instead, good program, but I suspect mp3tag can do all I require.
Thanks
Actually, I don't use "context menu" option, I am talking about dragging'n'dropping one file into MP3tag windows. I also tried adding "/fp:%1" (both with and without quotes) to the MP3tag shortcut, but it didn't help neither.
