have been using for years, updated for the first time in a while from 2.91 to 2.97, later on noticed that some tags created in older files do not show anymore. After a while of doubting my encoding (dbpoweramp) and re-entering tags without progress and NOT DOUBTING MP3TAG cos it has always been "OK", downgraded back to 2.91 and all tags are there.
Trouble is I only thought of downgrading after re-encoding and RE-Entering many hundreds of albums. What a waste of time..
You could have checked the settings in File>Options>Tags>Mpeg in respect to APE tags.
Also, you could check your files if you have APE tags with the filter
%_tag% HAS APE.
As APE tags overrule the display of other tags, it could be that empty APE fields hide the filled ID3V2 tag fields.
Usually the settings are kept.
But if you choose a different way of installation (normal vs. portable), install a portable version in a different folder than before, the settings are reset to default.
So I would check the files for APE tags as apparently they are out of sync with the other tags.
The best way would be to remove APE tags altogether.
