Hi all,
I want concurrent drag n drop support. I mean currently in mp3tag I drop a audio file into the application from Explorer (normal) but when I drag another file into the same session then the existing file is removed from editting pane. I know one can drag n drop batch files at the same time but it would still be nice if an option to drag per file same session can be supported.
Back to editting pane.... support for Highlighting of changes (in memory editting), I really would love this feature as a tickbox enable/disable feature so users enjoy the convenience
